Page 3 of 15 1 2 3 4 5 14 15
Re: 5.7 Hemi in a 67 Barracuda [Re: Clair_Davis] #17407
10/18/05 10:12 PM
10/18/05 10:12 PM
Midland, Va.
57HemiDart Offline
57HemiDart  Offline
Midland, Va.
Daty,
I called Don before I left work today. He was on the phone with someone else and asked me to call in the morning.
So is his solution an in-tank pump or an external pump?
I need to figure out a belt solution also. I will not be using A/C or power steering. I did get a bracket/pulley from the dealer that takes the place of the A/C unit. I'm assuming at this point that this bracket has the same dimensions for the belt as the A/C unit would have. If that's true than I need a belt for a non-power steering situation.
57HemiDart -->
(Bob)
Re: 5.7 Hemi in a 67 Barracuda [Re: Clair_Davis] #17408
10/18/05 11:58 PM
10/18/05 11:58 PM
Texas
Daty Rogers Offline OP
World's Greatest Husband. I love you Robyn
Texas
Changing the tensioner to running inside is a good idea, I'll see if I can make that work. thanks!
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: 57HemiDart] #17409
10/19/05 12:01 AM
10/19/05 12:01 AM
Texas
Texas
We're running an external pump. I'll post a pic of my pulley situation in the morning and we can compare, I'm going to try Clair's idea of running the tensioner the other way and see if I can get that to work.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: 57HemiDart] #17410
10/19/05 04:06 AM
10/19/05 04:06 AM
Texas
Texas
Bob,
I'd like a pic of your pulley arrangement (esp the a/c replacement bracket). thanks!
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17411
10/19/05 09:06 AM
10/19/05 09:06 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Great thread, thanks for the pics!
FWIW, you guys probably already know this, but back in August Bouchillon mentioned they have an accessory drive kit in the works...
Re: 5.7 Hemi in a 67 Barracuda [Re: ZIPPY] #17412
10/19/05 12:05 PM
10/19/05 12:05 PM
Texas
Texas
No I haven't, but I have (hopefully) great news, the Durango idler pulleys are 3.5" across instead of 3" across, and with two idlers I have a whole new range of belt sizes to sacrifice. What may end up working is instead of going in/out/in/out I used the top idler inbetween the a/c and the alternator, so instead of having a .5" belt range in the tensioner I have about 2" range instead and by golly there is a good belt number in the top half of that range and will pick it up in a couple hours.
We now have a two pager thread going!
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17413
10/19/05 03:27 PM
10/19/05 03:27 PM
Texas
Texas
SUCCESS!!!!!!!!
I found with two 99 360 Durango idler pulleys (pn 53009508) and Gates K070834 I have the tensioner about middle range, I'm so happy I can go to sleep now...
Attached is a pic of my now finished front of the motor.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17414
10/20/05 08:22 AM
10/20/05 08:22 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
looks good. no power steering?
2017 Grand Cherokee Overland
Re: 5.7 Hemi in a 67 Barracuda [Re: patrick] #17415
10/20/05 09:36 AM
10/20/05 09:36 AM
Texas
Texas
Can't use power steering with the TTI headers and mounts. The vert is manual steering anyway so it didn't concern me (that is until I tried to get a belt setup that would work).
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17416
10/20/05 11:14 AM
10/20/05 11:14 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
What's the issue with the fuel system?
Slap a Vortec T-Rex inline fuel pump in there and install a regulator up front. Mine draws from a 3/8" pickup but you'll be fine using the stock 5/16 for your application.
What's the problem with those? I have been running mine for several years on the TT440.
Is it a returnless system?
BTW... I've been wanting to do one of those swaps. I just don't have another car (or the spare funds) to do it.
Daty, I think I've seen your fishy. I'm in Irving. Drop me a line. I'd like to see the setup.
- Stu Harmon
Re: 5.7 Hemi in a 67 Barracuda [Re: feets] #17417
10/20/05 11:33 AM
10/20/05 11:33 AM
Texas
Texas
Don't have one anymore. I am switching from a carb car to an MPI car. The tank is being replaced with a sumped/baffled/stock unit, two lines out the sump; -10 to a bg mighty enduro, -8 to the front to a regulator/filter, down to the rail, out to a -06 back to the tank. Whe whole setup will run less than $1500, a bargin for all new and trouble free. The motor has the rest like rails, throttle body injectors, computors, sensors, wiring. It's a really cool system so far. I parked next to you at last years picnic, I have the old man tan slant 6 you wanted to turbocharge. You're more than welcome to come by, pm and we can figure out a time.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17418
10/20/05 11:36 AM
10/20/05 11:36 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
-Daty
He says that to everybody, Daty!
Clair
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17419
10/20/05 11:48 AM
10/20/05 11:48 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Why the huge fuel system? Are you planning on really stepping up that little Hemi?
The fuel pump I listed onle cost a little over $200. I've got a complete AN braided line system and spent only a fraction of what you're talking.
I thought I knew the car. It's quite nice. Parking it next to mine made it look even better.
- Stu Harmon
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17420
10/21/05 12:22 AM
10/21/05 12:22 AM
Midland, Va.
57HemiDart Offline
57HemiDart  Offline
Midland, Va.
I'll try to get a pic of the pulley arrangement. The non-A/C bracket isn't on the engine yet but I can mount it temporarily. I need the correct length bolts for it.
Bob
Re: 5.7 Hemi in a 67 Barracuda [Re: feets] #17421
10/21/05 03:55 AM
10/21/05 03:55 AM
Texas
Texas
I'm planning for the future engine upgrades, that and the last thing I want to do is burn my motor for lack of fuel. Don is also sending lots of extra fittings and extra length on the hoses so I can cut to fit. I expect by the time I'm done to have only 1100 or so and half of that is the tank. Don said send everything back I don't use (including hoses over 6") and he'll refund the rest.
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: 57HemiDart] #17422
10/23/05 10:00 PM
10/23/05 10:00 PM
Midland, Va.
57HemiDart Offline
57HemiDart  Offline
Midland, Va.
Daty,
I attached a pic of my engine with the non-A/C bracket/pulley and the alternator in place..
Bob
Re: 5.7 Hemi in a 67 Barracuda [Re: 57HemiDart] #17423
10/23/05 10:09 PM
10/23/05 10:09 PM
Texas
Texas
http://www.gatespowerpro.com/Comergent/en/US/adirect/gates?cmd=catNavigate2
You may need the kd70825, and you may need to use larger Durango idler pulleys. Have you measured for a belt yet? I'd try the same routing I did on mine a few messages up, use an old belt instead of a string though, the string came up woefully short for me. Clair helped me out a lot on my belt deal, it was beating me up pretty good.
I noticed you painted the intake black, nice...
-Daty
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17424
10/23/05 10:13 PM
10/23/05 10:13 PM
Seminole County FL to Plymouth...
Barry70GTX Online content
Barry70GTX  Online Content
I'll be installing a 5.7/Tremec in an A body in the near future. Keep us updated on how it goes.
NMCA NSS 67 Coronet
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17425
10/23/05 11:30 PM
10/23/05 11:30 PM
Midland, Va.
57HemiDart Offline
57HemiDart  Offline
Midland, Va.
Daty,
I haven't measured for a belt yet. I don't have an old belt. I know the parts manager at my local Dodge Dealer. He can probably get me an old one or let me bring a new one back if it doesn't fit.
I'll try a belt first before I buy the Durango pulleys.
Bob
Re: 5.7 Hemi in a 67 Barracuda [Re: Daty Rogers] #17426
10/23/05 11:38 PM
10/23/05 11:38 PM
Midland, Va.
57HemiDart Offline
57HemiDart  Offline
Midland, Va.
I didn't paint the intake black.. It's the factory black plastic intake. I'm not using that one. I want to use the Mopar Performance parts. The same stuff that's on the crate engine.
Are things flying kind of fast for you there Daty (LOL)?
I guess you are the leader in this pioneering effort here. And you're doing a good job of it.
Once I am on vacation next week, hopefully I'll get a little further along with my project.
Thanks,
Bob
