Re: is there a gasket underneath the valley pan on a 400?
[Re: Supercuda]
#1740360
01/27/15 06:43 PM
01/27/15 06:43 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
I went to put an edelbrock 1406 on my stock 400. The eddy is a spead bore and the stock intake is a spread bore. But I didnt look close enough, the spead bore holes on the intake are further apart than the eddy, so the eddy blades are blocked an cant open.
If you used a thick carb base gasket the 1406 would have worked, at least it does on my LA intake.
Even with a thick gasket the intake still would have left a large ledge for the fuel mixture to travel over and I didn't like that idea
[Re: elmor353]
#1740364
01/28/15 12:53 PM
01/28/15 12:53 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
If you are putting an aluminum intake on it, I would also install Fel-Pro MS90175 composite gaskets on both sides of the valley pan. The valley pan will seal to the cast iron head surface, but it doesn't like to seal against the aluminum intake surface. I found out the hard way. Massive vacuum leaks around the intake. I used the same valley pan with the MS90175 gaskets to sandwich it and it's been running great for 3years now. Definitely use a little RTV in each corner under the valley pan.
Yup. The general rule of thumb: Aluminum manifold? use the add-on paper gaskets.
Rick
[Re: Adam71Charger]
#1740367
01/28/15 10:52 PM
01/28/15 10:52 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I always thought it meant Spread bore has smaller primaries and larger secondary's. A spread. Square bore being all four bores are the same size. A square.
I have mechanical Aptitude. I can screw up anything.
[Re: dogdays]
#1740368
01/29/15 03:58 PM
01/29/15 03:58 PM
Adam71Charger
An Edelbrock 1406 is NOT a spreadbore carb. The only Edelbrock carbs that were spreadbores were the Edelbrock Quadrajets. Some of the carter AVS and AFB carbs had larger secondaries than primaries, but they were all squarebore carbs. The only Carter carb that was a spreadbore was the Thermoquad, however they did build some Quadrajets for GM.
But your 1406 is a garden variety 625cfm AFB and needs an adapter to work on a spreadbore intake.
The Street Demons are the only carbs that fit on either type of base. And the 650 is supposed to be great right out of the box. That's what I'd suggest.
R.
This is the bottom of my 1406, isnt this a spread bore? Secondaries are larger than primaries
[Re: Adam71Charger]
#1740369
01/29/15 04:21 PM
01/29/15 04:21 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
1406 is not a spread bore.It does have smaller primaries but that does not make a spread bore.
Leave the gun.......take the Cannoli's....Mike
[Re: Adam71Charger]
#1740370
01/31/15 08:35 AM
01/31/15 08:35 AM
Posts: 19,456 north of coder
moparx
R.
spreadbore think : thermoquad, quadrajet[gm], and some holleys[possibly including the mid 70's "three" bbl.] every thing else is square bore, though some had secondary butterflys slightly larger than the primarys.
