Pics of EVAC systems please.. #173926
12/24/08 10:31 AM
12/24/08 10:31 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I am going to have the one way valve welded into my headers, but want to see pics of how you did it. Also interested in seeing top dollar installations.. unlike my generic kit. Thanks.
RS23L7 4-Speed
Re: Pics of EVAC systems please.. [Re: Mopar_Mike] #173927
12/24/08 12:19 PM
12/24/08 12:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I always use a pipe nipple to weld into the collector,
cut the one end at a 45* angle and install it
in the middle of the collector making sure that
the flat of the 45* is parallel with the collector exit.
If you want to fancy it up for a touch better flow
grind the forward side of the nipple thinner for
better flow. I'll see if I have any pics
Re: Pics of EVAC systems please.. [Re: MR_P_BODY] #173928
12/24/08 01:57 PM
12/24/08 01:57 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
me too want pics
Re: Pics of EVAC systems please.. [Re: dirtybee] #173929
12/24/08 02:42 PM
12/24/08 02:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Here is one set. Remember that once its outside
of the collector you can make it any length you
want to where you mount the valve(for clearance reasons)
Re: Pics of EVAC systems please.. [Re: MR_P_BODY] #173930
12/24/08 02:45 PM
12/24/08 02:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Outside
Re: Pics of EVAC systems please.. [Re: MR_P_BODY] #173931
12/24/08 04:04 PM
12/24/08 04:04 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Re: Pics of EVAC systems please.. [Re: AAR-B4] #173932
12/24/08 04:15 PM
12/24/08 04:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Moroso instructions:
http://www.moroso.com/catalog/images/25900_inst.pdf
That doesnt give the greatest negitive pressure, I
did a ton of testing in the exhaust lab just to find
out what is the best way. Sure that will pull some
but it isnt the best
But you can put it in in either way if you wish
Re: Pics of EVAC systems please.. [Re: MR_P_BODY] #173933
12/24/08 06:30 PM
12/24/08 06:30 PM
fullmetaljacket Offline
P-body. It seems like you have the evac tube welded on the collectors side faces, Am I correct?
The Moroso instructions say to put them on the very top portion of the collectors, but I'll take note to what you suggest and install it that way if that is the best way.
Re: Pics of EVAC systems please.. [Re: fullmetaljacket] #173934
12/24/08 11:49 PM
12/24/08 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can put it in in either place that you have clearance
for, just point it down a little so it doesnt hold
moistue/water in it and it drains into the collector
