Pics of EVAC systems please..
#173926
12/24/08 10:31 AM
12/24/08 10:31 AM
Posts: 4,282 Danville, NH
Mopar_Mike
Danville, NH
I am going to have the one way valve welded into my headers, but want to see pics of how you did it. Also interested in seeing top dollar installations.. unlike my generic kit. Thanks.
RS23L7 4-Speed
Re: Pics of EVAC systems please..
[Re: Mopar_Mike]
#173927
12/24/08 12:19 PM
12/24/08 12:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I always use a pipe nipple to weld into the collector, cut the one end at a 45* angle and install it in the middle of the collector making sure that the flat of the 45* is parallel with the collector exit. If you want to fancy it up for a touch better flow grind the forward side of the nipple thinner for better flow. I'll see if I have any pics
[Re: dirtybee]
#173929
12/24/08 02:42 PM
12/24/08 02:42 PM
MR_P_BODY
Here is one set. Remember that once its outside of the collector you can make it any length you want to where you mount the valve(for clearance reasons)
[Re: fullmetaljacket]
#173934
12/24/08 11:49 PM
12/24/08 11:49 PM
MR_P_BODY
P-body. It seems like you have the evac tube welded on the collectors side faces, Am I correct? The Moroso instructions say to put them on the very top portion of the collectors, but I'll take note to what you suggest and install it that way if that is the best way.
You can put it in in either place that you have clearance for, just point it down a little so it doesnt hold moistue/water in it and it drains into the collector
