383 Stroker Reliability #1738885
01/26/15 01:23 PM
01/26/15 01:23 PM
Washington, D.C
69SportSat Offline OP
Washington, D.C
I'd like to know if anyone has experienced any reliability issues from a 438 or 496 stroker build on a 383? Considering building one for a non-track car. Thanks.
Re: 383 Stroker Reliability [Re: 69SportSat] #1738886
01/26/15 01:37 PM
01/26/15 01:37 PM
dogdays Offline
dogdays  Offline
Considering that Pontiac, Oldsmobile and Cadillac had OEM engines with 4.21, 4.25 and 4.31"strokes, respectively, there is no reason why a 4.25" stroke in a B or RB block would be any different.
Reliability depends on quality of parts, how it is assembled, and how it is used.
R.
Re: 383 Stroker Reliability [Re: 69SportSat] #1738887
01/26/15 02:47 PM
01/26/15 02:47 PM
Unless you have one of the really rare late 1971 blocks that where cast for the 400 motors you need to be very careful on tuning, no detonation Most of the 383 blocks had thin main webs like most RB blocks do If you have a forged steel BB crank I would have it offset ground down to BB Chevy rod journal size and the stroke to 3.91 or 3.90 stroke and have the mains and counterweights cutdown to use in your 383 block, those motors flat rock I've built a bunch of Mopar V8 of all sizes and types, the 3.91 stroke B and RB motors work really well on the street and strip
Re: 383 Stroker Reliability [Re: Cab_Burge] #1738888
01/26/15 03:45 PM
01/26/15 03:45 PM
Washington, D.C
Washington, D.C
I'm considering purchasing the kit from 440Source.
Re: 383 Stroker Reliability [Re: 69SportSat] #1738889
01/26/15 03:55 PM
01/26/15 03:55 PM
PA
Sir Valiant Offline
Sir Valiant  Offline
PA
I did my 383/450 stroker with a muscle motors kit, dropped right in!
Re: 383 Stroker Reliability [Re: 69SportSat] #1738890
01/26/15 05:19 PM
01/26/15 05:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you have to go past .030 have the block sonic checked , one member did his in a .060 over block that wasn't checked and it cracked a cylinder. Core shift is more of a problem in the early blocks.
Re: 383 Stroker Reliability [Re: Sir Valiant] #1738891
01/26/15 07:16 PM
01/26/15 07:16 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
For a street eng as long as you build it right you should not have any problems. I like to keep mine at no more then .030 over also and build good quench in it along with the right cam to be sure you dont get any spark knock/ping.
Sir Valaint thats a good looking bigblock. I am using the same valve covers. Ron
Re: 383 Stroker Reliability [Re: Sir Valiant] #1738892
01/27/15 03:01 PM
01/27/15 03:01 PM
Detroit, Michigan
N
njk53 Offline
njk53  Offline
N
Detroit, Michigan
Sir Valiant, Out of curiosity, how much $$$ did you get wrapped up in your engine build? A buddy of mine is also wanting to stroke a 383 and is getting numbers that are all over the place.
Re: 383 Stroker Reliability [Re: dogdays] #1738893
01/27/15 05:40 PM
01/27/15 05:40 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
R.
Hmmm. This gets complex. I have no idea what the deck height (from crank C/L to head gasket surface) is on the engines quoted, but the shorter the deck, and / or the longer the stroke, the shorter the piston needs to be to fit. Once the skirt gets very short, esp. with short rods, there's lots of side thrust / loading which is not conducive to longevity or durability. I think that, for many of us, the engineered-in robustness of Mopars is part of the attraction.
Since B and RB engines have, generally, the same bottom end (of the block) patterns, I build lowbuck B strokers (RB crank) by boring the main saddles to RB size. This way the crank is OEM strength (as is the bottom end of the block).
Of course, lots of different combos can be assembled, and most work quite well, but the original question was regarding reliability...
Rick
Re: 383 Stroker Reliability [Re: Rick_Ehrenberg] #1738894
01/28/15 12:26 AM
01/28/15 12:26 AM
Washington, D.C
Washington, D.C
I appreciate everyone's feedback. Reliability was the original question. The motor is going to be professionally built and dyno'd before installation. Can anyone provide their opinion - Muscle Motors versus 440source 383 stroker kits (reliability or other comments)?
Re: 383 Stroker Reliability [Re: Cab_Burge] #1738895
01/28/15 07:32 AM
01/28/15 07:32 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
In case you missed this.........
Go to the 440Source website and look at the B/RB casting pic's, specifically the mainwebs.
A 440Source kit still needs to be thoroughly inspected by your builder. MuscleMotors will do all of that for you.
