Baxtek Alum Dana 60 Pro's n Cons #1737609
01/24/15 02:59 PM
01/24/15 02:59 PM
N.Y.
sixpacksteve Offline OP
N.Y.
thinking about buying one, aside from the weight which they claim 75-80lbs lighter, Not running in any class, what other benefits are there?
Hell Hath No Fury Like Mine
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: sixpacksteve] #1737610
01/24/15 03:46 PM
01/24/15 03:46 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Subscribing to this. I'm I need of a new Dana and 80 lbs. would be a nice weight loss.
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: Sammy] #1737611
01/24/15 03:57 PM
01/24/15 03:57 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Product Description
• 356-T6 aluminum housing
• Replaceable press-fit 3” DOM mild steel axle tubes
• 9qty – 3/8” bolts drilled and tapped into tubes for strength and for axle tube retention
• Accepts OEM components (Differentials, Gears and Axles)
• 70-80lbs weight savings over comparable factory cast iron unit
• Complete units ready for Mopar A, B, and E-Body cars
• Custom widths available at no charge
• 10 different gear sets available
NOTES:
• Bare housing available upon request
• Price listed is for a complete assembly with any gear, TrueTrac differential, bearings, 1350 yoke and a set of 35 spline Strange Engineering alloy axles
I wonder if thy are easy to setup like the Strange Dana 60's which eliminate the side shims.
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: sixpacksteve] #1737612
01/24/15 04:47 PM
01/24/15 04:47 PM
NY usa
540challenger Offline
NY usa
Anyone have a link to the company's website I couldn't find it???
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: 540challenger] #1737613
01/24/15 04:56 PM
01/24/15 04:56 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
http://dev2.floridaswebdesign.com/baxtekmoto/product/test5/
Kevin
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: Twostick] #1737614
01/24/15 05:46 PM
01/24/15 05:46 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Hopefully the engineering and casting quality is far above the welding skills pic.
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: Twostick] #1737615
01/24/15 05:56 PM
01/24/15 05:56 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
It looks to be a next step up in the evolution of the Dana 60 from truck rear to a real purpose built race rear. You can mount a pinion snubber to the case (only God knows why you would though), the axle tubes are bolted in place, the backlash is adjustable like the cast iron S60 and the weight savings puts it right there with the 9" Ford without it's weakness. If I was building a Cadillac bracket beast and had very deep pockets, I would go for it
Fortunately, my truck Dana is already built and the budget is under control
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: Polarapete] #1737616
01/24/15 06:03 PM
01/24/15 06:03 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
So if the axle tubes are aluminum, who would make a coil over bracket in aluminum instead of steel to weld to the housing?
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: Sammy] #1737617
01/24/15 06:12 PM
01/24/15 06:12 PM
NY usa
NY usa
according to the description the tubes are steel
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: 540challenger] #1737618
01/24/15 06:23 PM
01/24/15 06:23 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
You would be taking an expense gamble.
Why not go with a tried and true Strange 9" aluminum center and fabbed housing. Might be lighter, certainly cheaper.
My and worth every penny.
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: 540challenger] #1737619
01/24/15 07:08 PM
01/24/15 07:08 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I missed that.
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: Sammy] #1737620
01/24/15 08:43 PM
01/24/15 08:43 PM
N.Y.
N.Y.
correct me if i'm wrong. the strange 60 tubes are thinner! i used a truck rear and narrowed it, has that extra rib. after twisting and destroying a 8 3/4 rear, dana would be the only way.
Has anyone purchased one?
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: sixpacksteve] #1737621
01/24/15 09:39 PM
01/24/15 09:39 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Where is my 10 foot pole ..
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: go green] #1737622
01/24/15 10:14 PM
01/24/15 10:14 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
What he said, there are plenty of places to save some weight but that rear just doesn't look like something I want to drop the clutch on
Gus
64 Plymouth Savoy
Dana 60
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: fourgearsavoy] #1737623
01/24/15 11:06 PM
01/24/15 11:06 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I don't like the way the tubes are bolted to the center section. For that kind of money, you could buy one heck of a nice 9" sheet metal rear axle assembly.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: Leigh] #1737624
01/25/15 01:07 AM
01/25/15 01:07 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
that ring and pinion pattern is leaving something to be desired
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: go green] #1737625
01/25/15 01:44 AM
01/25/15 01:44 AM
Arizona
Chris'sBarracuda Offline
Arizona
Anyone spending that much for that piece should have their head examined..
Chris..
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: sixpacksteve] #1737626
01/25/15 02:16 AM
01/25/15 02:16 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I like it, except one detail, I'm uneasy about the axle tube retention solution, not sure how robust and what power limits those bolts will handle. It says 9 3/8", is that per tube? I couldn't make out in pics.
I have an old Dana 60 Magnesium housing, it has 8? 1/2" studs on a 5"? BC retaining its axle tubes, likely far tougher then 3/8" on an effectively 3"? circle.
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: jcc] #1737627
01/25/15 10:37 AM
01/25/15 10:37 AM
N.Y.
N.Y.
i would of thought they'd post how much HP it could handle.
or show some test vehicle. other than saving weight why would some one buy it?
Re: Baxtek Alum Dana 60 Pro's n Cons [Re: sixpacksteve] #1737628
01/25/15 11:41 AM
01/25/15 11:41 AM
fullmetaljacket Offline
I offered them almost eight months back to use my lightweight project car to test and tune in real world street and track, but..............they found no interest at the time. Maybe they'll come around.
