Baxtek Alum Dana 60 Pro's n Cons
#1737609
01/24/15 02:59 PM
01/24/15 02:59 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
thinking about buying one, aside from the weight which they claim 75-80lbs lighter, Not running in any class, what other benefits are there?
Hell Hath No Fury Like Mine
Re: Baxtek Alum Dana 60 Pro's n Cons
[Re: Sammy]
#1737611
01/24/15 03:57 PM
01/24/15 03:57 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Product Description
• 356-T6 aluminum housing • Replaceable press-fit 3” DOM mild steel axle tubes • 9qty – 3/8” bolts drilled and tapped into tubes for strength and for axle tube retention • Accepts OEM components (Differentials, Gears and Axles) • 70-80lbs weight savings over comparable factory cast iron unit • Complete units ready for Mopar A, B, and E-Body cars • Custom widths available at no charge • 10 different gear sets available
NOTES: • Bare housing available upon request • Price listed is for a complete assembly with any gear, TrueTrac differential, bearings, 1350 yoke and a set of 35 spline Strange Engineering alloy axles
I wonder if thy are easy to setup like the Strange Dana 60's which eliminate the side shims.
[Re: Twostick]
#1737615
01/24/15 05:56 PM
01/24/15 05:56 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
It looks to be a next step up in the evolution of the Dana 60 from truck rear to a real purpose built race rear. You can mount a pinion snubber to the case (only God knows why you would though), the axle tubes are bolted in place, the backlash is adjustable like the cast iron S60 and the weight savings puts it right there with the 9" Ford without it's weakness. If I was building a Cadillac bracket beast and had very deep pockets, I would go for it Fortunately, my truck Dana is already built and the budget is under control
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Sammy]
#1737617
01/24/15 06:12 PM
01/24/15 06:12 PM
Posts: 2,826 NY usa
540challenger
NY usa
So if the axle tubes are aluminum, who would make a coil over bracket in aluminum instead of steel to weld to the housing?
according to the description the tubes are steel
[Re: 540challenger]
#1737618
01/24/15 06:23 PM
01/24/15 06:23 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
You would be taking an expense gamble. Why not go with a tried and true Strange 9" aluminum center and fabbed housing. Might be lighter, certainly cheaper. My and worth every penny.
[Re: 540challenger]
#1737619
01/24/15 07:08 PM
01/24/15 07:08 PM
Sammy
Wind Gap,Pa.
I missed that.
[Re: Sammy]
#1737620
01/24/15 08:43 PM
01/24/15 08:43 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
correct me if i'm wrong. the strange 60 tubes are thinner! i used a truck rear and narrowed it, has that extra rib. after twisting and destroying a 8 3/4 rear, dana would be the only way. Has anyone purchased one?
[Re: fourgearsavoy]
#1737623
01/24/15 11:06 PM
01/24/15 11:06 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I don't like the way the tubes are bolted to the center section. For that kind of money, you could buy one heck of a nice 9" sheet metal rear axle assembly.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: go green]
#1737625
01/25/15 01:44 AM
01/25/15 01:44 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Where is my 10 foot pole ..
Anyone spending that much for that piece should have their head examined..
Chris..
[Re: sixpacksteve]
#1737626
01/25/15 02:16 AM
01/25/15 02:16 AM
Posts: 22,696 Bitopia
jcc
Bitopia
I like it, except one detail, I'm uneasy about the axle tube retention solution, not sure how robust and what power limits those bolts will handle. It says 9 3/8", is that per tube? I couldn't make out in pics.
I have an old Dana 60 Magnesium housing, it has 8? 1/2" studs on a 5"? BC retaining its axle tubes, likely far tougher then 3/8" on an effectively 3"? circle.
[Re: jcc]
#1737627
01/25/15 10:37 AM
01/25/15 10:37 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i would of thought they'd post how much HP it could handle. or show some test vehicle. other than saving weight why would some one buy it?
