04 ram 2500 intermittent starting problem #1737557
01/24/15 01:55 PM
01/24/15 01:55 PM
Cleveland Ohio
sportfury70 Offline OP
Cleveland Ohio
My 04 Ram has an intermittent problem starting. It started out of the blue in October. I took it to a garage to replace parking brake cables and got a call from the tech saying it will not crank. It eventually started. When I picked it up I had to hit the key several times. Then I didn't have a problem for 2 months. Now it wont start again. I suspected the clutch interlock switch. I bypassed it and still no crank. Is there a common problem with these? Ignition switch possibly?
Thanks. Lew
Re: 04 ram 2500 intermittent starting problem [Re: sportfury70] #1737558
01/24/15 04:40 PM
01/24/15 04:40 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Does it click? My 2002 had bad starter solenoid contacts that were intermittent.
Re: 04 ram 2500 intermittent starting problem [Re: NITROUSN] #1737559
01/24/15 04:51 PM
01/24/15 04:51 PM
Cleveland Ohio
Cleveland Ohio
No click. Nothing at all. That's why I thought is may be the clutch interlock switch. Very random. Doesn't matter if it's hot or cold. It sat for 2 weeks in December because it would not start one morning. The next time I tried it, it fired right up no problem at all.
Re: 04 ram 2500 intermittent starting problem [Re: sportfury70] #1737560
01/24/15 05:54 PM
01/24/15 05:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
There is a relay in the under hood power distribution box. Try swapping with another. Does the truck have a security system?
Re: 04 ram 2500 intermittent starting problem [Re: NITROUSN] #1737561
01/24/15 07:11 PM
01/24/15 07:11 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
next time it won't crank,use a test light and see if there is power at the starter.(small wire) while the key is in the crank position,( will need a second person),if YES =replace starter.sometimes a slight tap on the starter if a no crank will jar it enough to crank.weather,moisture and temperature cause electrical intermittent problems.
Re: 04 ram 2500 intermittent starting problem [Re: moretoys] #1737562
01/24/15 07:48 PM
01/24/15 07:48 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You don't need to replace the starter as most of the time a simple replacement of the solenoid contacts will make it good for another 100,000 miles.
Re: 04 ram 2500 intermittent starting problem [Re: NITROUSN] #1737563
01/25/15 02:15 AM
01/25/15 02:15 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
Re: 04 ram 2500 intermittent starting problem [Re: rhad] #1737564
01/31/15 12:32 PM
01/31/15 12:32 PM
Cleveland Ohio
Cleveland Ohio
Well it happened again. I crawled under truck & tapped the starter with a hammer. Starter was loose!
Torqued them down real good & she fired right up!. Thanks guys!
Lew
