Re: 04 ram 2500 intermittent starting problem
[Re: moretoys]
#1737562
01/24/15 07:48 PM
01/24/15 07:48 PM
Posts: 18,407 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
next time it won't crank,use a test light and see if there is power at the starter.(small wire) while the key is in the crank position,( will need a second person),if YES =replace starter.sometimes a slight tap on the starter if a no crank will jar it enough to crank.weather,moisture and temperature cause electrical intermittent problems.
You don't need to replace the starter as most of the time a simple replacement of the solenoid contacts will make it good for another 100,000 miles.
[Re: NITROUSN]
#1737563
01/25/15 02:15 AM
01/25/15 02:15 AM
Posts: 954 garnett kansas
rhad
garnett kansas
