Another brake question....Master Cylinder issue?
#1737424
01/24/15 04:17 AM
01/24/15 04:17 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I noticed the other active brake thread so I thought Id ask about my braking system.
The brakes work OK, not great but OK. The car stops fine, but the brakes wont lock up (front or back).
The car is in my sig. My system consists of 10.75 front discs, 11 inch drums rear. No booster, manual. The calipers are from a 72 Challenger. The master is a MP unit from the late 90s. I do believe it is a 1.125 bore. Not 100 percent on the bore size, but I do know it was bigger of two sizes listed in the MP catalog in 1998ish. I do have a dial type prop valve in the rear brakes.
Ive had the car back together for about 5 years. I drive it on the street as well as track.
But, I feel they arent "right" as I cant make them lock up. The pedal feel is good, not overally stiff or soft.
I assume I need a smaller bore master. Something around a 7/8 inch unit?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Another brake question....Master Cylinder issue?
[Re: Von]
#1737427
02/01/15 02:59 AM
02/01/15 02:59 AM
RapidRobert
My 65 dart had 76 A body 10.87" discs (2.75" pistons same as yours). 1&1/8 truck dual alum MC. 10" later 7&1/4 brakes & it will lock em up with enough pedal (rears first). Not sure what your exact problem is but my components are similar to yours.
[Re: Von]
#1737429
02/01/15 08:29 AM
02/01/15 08:29 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Up. Anymore ideas?
I would find out exactly what bore-diameter you have now and go one size smaller. Going from 1.125" to 7/8" is way too much of a step and most likely won't work if you have a proper manual brakepedal ratio in the car.
If you don't have a residual valve in the rear brake-line I would get one as well.
[Re: Von]
#1737430
02/01/15 12:00 PM
02/01/15 12:00 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
Have you checked the brake safety switch? If the o-rings in it are no good, the brakes won't work very well. To check it, just take out the switch. If there is fluid behind the switch, the o-rings are no good. If no fluid, it is fine. This was the problem on my Dad's Cuda. We could not get the brakes to lock up (disc/drum). We tried everything, new master, booster, fluid, rebuild calipers and wheel cylinders. Nothing worked until we rebuilt the safety switch. Brakes work great now. Here is a link on how to rebuild. Link
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
[Re: D149]
#1737431
02/01/15 12:33 PM
02/01/15 12:33 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
That is not a combination valve, which is what you want in a disc/drum combo.
[Re: Cab_Burge]
#1737432
02/06/15 08:05 PM
02/06/15 08:05 PM
Von
NE Oklahoma
Try adjusting the proportioning valve until the back tires lock up and then set it so it just won't and see how you like that with the present parts That is a big car Stay safe
No matter where I have the prop valve, neither front or rear locks.
[Re: BigBlockMopar]
#1737433
02/06/15 08:06 PM
02/06/15 08:06 PM
Von
NE Oklahoma
Up. Anymore ideas?
So try a 1 inch master or a size between 1 and 1.125. I do have a pedal from a manual brake car.
Why the residual valve in this app?
[Re: D149]
#1737434
02/06/15 08:08 PM
02/06/15 08:08 PM
Von
NE Oklahoma
Safety switch is gone...
[Re: ahy]
#1737436
02/07/15 02:33 PM
02/07/15 02:33 PM
Von
NE Oklahoma
I may be way off base...but I dont think car weight is an issue. My car weighs no more or within a few lbs of the average BB e body. I have shucked quite a bit of weight off it. Just wondering...how does a similar system work in an e body?
Also, it has been my experience that an "under braked" vehicle usually locks the brakes easily? For instance, ( I know not an exact dollar to dollar comparison) my nissan pickup will lock the brakes way too easy if you put a trailer on it.
This car had 4 wheel manual drums from the factory. It didnt stop as "good" as the current setup, but it would lock all 4 if need be. The car weighs at least 300lbs less than those days.
As far as linkage, I have a pedal from a 71 RR manual brake car. The rod is, I believe, an adjustable rod from master power.
What are the measurements to verify that I have the correct pedal?
Could an incorrect pedal height, too low for instance, be helping cause the issue?
The car does stop pretty decent. On a short 1/8 mile track without much shut down area, I have to lock her down pretty good, but it does it fine. I just dont think that not being able to lock either front or rear is "correct"?
[Re: Andrewh]
#1737438
02/07/15 03:44 PM
02/07/15 03:44 PM
Von
NE Oklahoma
reading the original post, I do believe you are correct. you need a smaller bore mc.
here is why. The amount of force you are applying does not equate to enough force at the calipers to lock up the brakes. by using a smaller master, the math showed for me an increase of over 100 ft pounds of force applied at the calipers over the larger master that I was using.
since you don't have a booster, this is the only way to increase your brake force applied.
feets excel sheet shows that just by changing the master cylinder, no other differences, makes a huge amount of force difference.
I found that out too real world, that I could lock mine up after that.
Thanks for your input!
How much smaller did you go in MC bore size?
Is feets excel sheet available on here or should I PM him for it?
[Re: feets]
#1737440
02/07/15 08:33 PM
02/07/15 08:33 PM
Andrewh
I only had one choice because of the aftermarket brakes. 1 and 1/8 down to 1 inch. that 1/8th was a huge improvement. they didn't make a smaller one for my application. there were a few people that adapted some from other cars, but I figured that was a worst case thing, trying to find a 7/8ths. and you can download it from http://3gduster.com/brakes.html
