Tire Selection #1736927
01/23/15 03:28 PM
01/23/15 03:28 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
I have never looked into radial drag tires before but now I found a tire size that fits exactly what I want.
What is your expierence with radial tires.
The car had 28x10.5 Stiff wall Hoosier and hooked real well. I need a taller tire to get the gearing right on the money.
Any help would be great!
Re: Tire Selection [Re: Biginchmopar] #1736928
01/23/15 11:09 PM
01/23/15 11:09 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
im pretty sure hoosier makes a 30x10 radial slick, ive never run a radial slick-ran drag radials but im talking about a slick but we have a customer that does and he got another 2-3 mph out of them, I would think hooking would prove more difficult but I am certainly no expert. drag radials need a well prepped(for drag radials) suspension and I hated running them personally but there are cars that haul ass on them
Re: Tire Selection [Re: upnover] #1736929
01/23/15 11:35 PM
01/23/15 11:35 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
If you are talking about a radial drag slick
I have run both m/t and hoosier 30x9 drag radial slicks.
The m/t slick hooked good on a good track but if they spin at the hit your done they will not recover. I got less than 50 runs before the thread showed and they went away all at once!!
The Hoosiers hook great again on a good track, they will recover somewhat better if they spin. I have over 50 runs my set and the still look good.
Biggest thing with a radial slick is the track prep has to be good for them to work. Put 18-24 psi in them and enjoy the ride.
My car picks up over a tenth with radials vs a bias slick.
Re: Tire Selection [Re: Biginchmopar] #1736930
01/23/15 11:40 PM
01/23/15 11:40 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have a set of 315/60 M/T drag radials on 10 in rims and a set of 29.5/10.5 W slicks on 14 in rims. I went to a test & tune and tried both and ran a .11 faster with the Drag Radials and dead hooked with both. It was 1/8 mile track.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Tire Selection [Re: nss guy] #1736931
01/24/15 12:32 AM
01/24/15 12:32 AM
Carson City, Nevada
Carson City, Nevada
Yes I'm looking at Drag Slick Radials
I'm looking at these tires:
Hoosier - 30.0/10.5R-15 Radial***
The car is a 4-speed car that has about 550HP to the tire. Cal Tracs, Cavert Mono leaf, Rancho 9000 shock
1969 Roadrunner
Re: Tire Selection [Re: Biginchmopar] #1736932
01/24/15 12:40 AM
01/24/15 12:40 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
1969 Roadrunner
Four speed go bias.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Tire Selection [Re: 1967dartgt] #1736933
01/24/15 12:48 AM
01/24/15 12:48 AM
Carson City, Nevada
Carson City, Nevada
Because of the shock on the tire?
Re: Tire Selection [Re: Biginchmopar] #1736934
01/24/15 12:53 AM
01/24/15 12:53 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes, four speeds and radials don't mix well. You can make it work but you will pull your hair out for a year trying to get it.
Re: Tire Selection [Re: 1967dartgt] #1736935
01/24/15 02:23 AM
01/24/15 02:23 AM
None of the NHRA stocker 4 speed guys use radials, none of them
Re: Tire Selection [Re: 1967dartgt] #1736936
01/24/15 03:04 AM
01/24/15 03:04 AM
Carson City, Nevada
Carson City, Nevada
Hair is no big deal, I'm pretty much bald.
Thanks for the help guys.
Re: Tire Selection [Re: Cab_Burge] #1736937
01/24/15 03:23 AM
01/24/15 03:23 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'd call that a tell.
Re: Tire Selection [Re: tubtar] #1736938
01/24/15 06:57 PM
01/24/15 06:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have also heard from guys running 4-speeds that they cant get the radial slicks to work good with 4-speeds. And I have heard that from alot of 4-speed drivers as they run Bias.
As for me I love the 30 x 9 radial slicks I run on my 63 but of course its an automatic. They work good for me with the auto. To bad they wont work good with stick cars. Ron
Re: Tire Selection [Re: 383man] #1736939
01/24/15 09:13 PM
01/24/15 09:13 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
you wouldn't happen to remember what the section width is on your 30x9,s would ya?
Re: Tire Selection [Re: bonefish] #1736940
01/26/15 02:24 AM
01/26/15 02:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I will have to go out in the garage and look as they list two different circumference 30 x 9 radial tires from Hoosier and I need to loo at the tire to remember which I used. I will try to get out in the garage tomorrow. Ron
