440 question
#1736282
01/22/15 01:32 PM
01/22/15 01:32 PM
Posts: 416 Georgia
KingTuna
Georgia
Another member on here has a motor for sale, and I have some general questions I wanted to ask some of you guys that build motors and have experience with different setups. I am supposed to go look at the motor and hear it run this weekend. The motor is for sale at a great price which has me very interested. What I do know is the motor is 9:1 compression, 288 duration cam, 452 unleaded heads. I have seen a video of the motor running, and it sounds good with a nice lope to it. The seller did not build the motor, so I don't have the exact cam specs. This is the only thing I am concerened with. I am planning on running the 2.94's I have now, and maybe upgrade to 3.23's later down the road. I am not looking to go any lower than that on rear end ratio. I was told that with that motor, I would need a stall converter similar to what came with a HP440, around an 1800-2000 stall. Would a stall like this work well with my gears? From the video and conversation, I figured it has a cam in between these two: http://www.summitracing.com/search/make/...891642%2B400304Another thing I thought about is simply doing a cam swap if the one in it is too big for what I want. I actually want to drive this car and be able to enjoy it and put miles on it.
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
Re: 440 question
[Re: KingTuna]
#1736283
01/22/15 01:39 PM
01/22/15 01:39 PM
Posts: 1,106 Northeast
VincentVega
Northeast
it's a little hard to say, since there's some guessing here, but I think you would be fine with that combination. By the way, there were many 440 torque converters, some as high as 2500-2800 from the factory. that would be great, but your mileage would hurt a little
That cam wouldn't be much more wild than a stock magnum cam, but with a reduction in compression and highway gears, you might get into some low speed bogging. but that can be tuned out through the carb with a vacuum secondary, quadajet, thermoquad, demon, etc
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 440 question
[Re: VincentVega]
#1736284
01/22/15 03:31 PM
01/22/15 03:31 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
what 440 combination had a 2500/2800 stall convertor ???
Re: 440 question
[Re: KingTuna]
#1736285
01/22/15 04:02 PM
01/22/15 04:02 PM
Posts: 416 Georgia
KingTuna
Georgia
I forgot to ask about how a cam similar to this one does on vacuum, as I will still be running power brakes.
Re: 440 question
[Re: elmor353]
#1736292
01/23/15 07:34 PM
01/23/15 07:34 PM
VincentVega
Northeast
If you have a particular grind you like, sometimes you can go with a more aggressive rocker ratio and get even more out of your heads with no worse drivability. Just watch out for Piston to valve clearance
Re: 440 question
[Re: KingTuna]
#1736293
01/23/15 11:28 PM
01/23/15 11:28 PM
Posts: 518 Georgia
Steve Bryant
Georgia
Last year, we built a 440 for my Cuda and built it pretty much to stock only we used a fairly tame CompCams 262 Int./270 Exh. 462 Int./.470 Exh.;Lobe 110 deg. I am also using an RPM Performer intake. I can smoke the 275/60s with ease in 1-3 gear and 4th with a little effort and the car cranks up instantly even on cold days, idles fairly smooth and has great manners and great performance (we pulled 390 on the Dyno) 452 Heads with a Port Job (from the Mopar Templates) stock sized valves and we used new pistons that gave us a 9:1. With a moderate 750 Holley it dyno'd at 390 hp. I run the HP Exhaust manifolds but the engine shop used headers for their tests. I also run an Eddie carb now. Here are the numbers: https://www.youtube.com/watch?v=jQzcBniEGkAHere is a short clip of the engine running on the dyno https://www.youtube.com/watch?v=T75EW-_v3PEI run a 4 speed with 4:10 on the rear so I can't help any with the converter but I am happy to share whatever I can about the build. My goal was to make a reliable driver with enough power to keep it fun.
