440 question #1736282
01/22/15 01:32 PM
01/22/15 01:32 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Another member on here has a motor for sale, and I have some general questions I wanted to ask some of you guys that build motors and have experience with different setups. I am supposed to go look at the motor and hear it run this weekend. The motor is for sale at a great price which has me very interested. What I do know is the motor is 9:1 compression, 288 duration cam, 452 unleaded heads. I have seen a video of the motor running, and it sounds good with a nice lope to it. The seller did not build the motor, so I don't have the exact cam specs. This is the only thing I am concerened with. I am planning on running the 2.94's I have now, and maybe upgrade to 3.23's later down the road. I am not looking to go any lower than that on rear end ratio. I was told that with that motor, I would need a stall converter similar to what came with a HP440, around an 1800-2000 stall. Would a stall like this work well with my gears? From the video and conversation, I figured it has a cam in between these two: http://www.summitracing.com/search/make/...891642%2B400304
Another thing I thought about is simply doing a cam swap if the one in it is too big for what I want. I actually want to drive this car and be able to enjoy it and put miles on it.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: 440 question [Re: KingTuna] #1736283
01/22/15 01:39 PM
01/22/15 01:39 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
it's a little hard to say, since there's some guessing here, but I think you would be fine with that combination. By the way, there were many 440 torque converters, some as high as 2500-2800 from the factory. that would be great, but your mileage would hurt a little
That cam wouldn't be much more wild than a stock magnum cam, but with a reduction in compression and highway gears, you might get into some low speed bogging. but that can be tuned out through the carb with a vacuum secondary, quadajet, thermoquad, demon, etc
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 440 question [Re: VincentVega] #1736284
01/22/15 03:31 PM
01/22/15 03:31 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
what 440 combination had a 2500/2800 stall convertor ???
Re: 440 question [Re: KingTuna] #1736285
01/22/15 04:02 PM
01/22/15 04:02 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
I forgot to ask about how a cam similar to this one does on vacuum, as I will still be running power brakes.
1966 Fury II 4 door
Re: 440 question [Re: KingTuna] #1736286
01/22/15 04:27 PM
01/22/15 04:27 PM
Texas
bogusracer Offline
bogusracer  Offline
Texas
Take a Vacuum Guage with you when you go to see / hear the engine run. Also it would be beneficial to have an oil pressure gauge to hook up and measure the Vacuum & Oil pressure at idle and at approx. 2500 - 3000 rpm. A dial back to zero timing light would help too. A Vacuum rating below 10psi or lower at idle will be marginal with power brakes. Record all of your reading and then post them for analysis on this site if you are not sure how to interpret the numbers. Also look down the throat of the carb and see if the primary and secondary throttle bblades on the carb are closed completely at idle. (Do this with the engine off) If they are partially open (beyond the idle transfer slot) then it means the carb is not the optimum match for the cam, and work will be required to correct. the short of it is that the blades can be open too far at idle rendering the idle circuit on the carb useless at idle, and your card idle screws will not function properly. Again post your findings here and ask for help to analyze them. This is a Great Resourse site for answers if you provide accurate details of what you have.
Good Luck !
Bogusracer
Re: 440 question [Re: JohnRR] #1736287
01/22/15 04:29 PM
01/22/15 04:29 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
late model cop cars had them to help with reduced engine output
Re: 440 question [Re: VincentVega] #1736288
01/22/15 05:58 PM
01/22/15 05:58 PM
dogdays Offline
dogdays  Offline
I believe there were actually only two torque converters per year and the high stall one had a little paper tag with "Hi Stall" on it. The differences in stall speeds on the chart above is largely explained by engine torque output.
R.
Re: 440 question [Re: KingTuna] #1736289
01/23/15 01:58 AM
01/23/15 01:58 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I'm running the bigger Summit cam in a 9.25 compression 440 in my D100 swb pickup. I'm using a Performer RPM intake, Hedman headers, a 750 vacuum secondary Holley(right out of the box), factory hi-stall convertor, 2.94 gears and 26 inch rear tires. This cam has a slight lope, but great street manners and it has stump pulling power. It will cruise at 30 mph all day and yet annihilate the 295/50-15's at will.
Re: 440 question [Re: elmor353] #1736290
01/23/15 12:22 PM
01/23/15 12:22 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Awesome, that's exactly what I was looking for. I just wanted to get real hand experience from someone making sure the combo would work well together. Do you run power brakes?
1966 Fury II 4 door
Re: 440 question [Re: KingTuna] #1736291
01/23/15 07:18 PM
01/23/15 07:18 PM
E
elmor353 Offline
elmor353  Offline
E
Yes, I do run power brakes. I haven't checked how much vacuum it's running, but the brakes work great. I like this cam so much that I'm putting together a 10-1 440 and going to use the same cam from Summit in it. It's one of the best all around street cams I've ever run.
Re: 440 question [Re: elmor353] #1736292
01/23/15 07:34 PM
01/23/15 07:34 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
If you have a particular grind you like, sometimes you can go with a more aggressive rocker ratio and get even more out of your heads with no worse drivability. Just watch out for Piston to valve clearance
Re: 440 question [Re: KingTuna] #1736293
01/23/15 11:28 PM
01/23/15 11:28 PM
Georgia
Steve Bryant Offline
Georgia
Last year, we built a 440 for my Cuda and built it pretty much to stock only we used a fairly tame CompCams 262 Int./270 Exh. 462 Int./.470 Exh.;Lobe 110 deg. I am also using an RPM Performer intake.
I can smoke the 275/60s with ease in 1-3 gear and 4th with a little effort and the car cranks up instantly even on cold days, idles fairly smooth and has great manners and great performance (we pulled 390 on the Dyno)
452 Heads with a Port Job (from the Mopar Templates) stock sized valves and we used new pistons that gave us a 9:1. With a moderate 750 Holley it dyno'd at 390 hp. I run the HP Exhaust manifolds but the engine shop used headers for their tests. I also run an Eddie carb now.
Here are the numbers:
https://www.youtube.com/watch?v=jQzcBniEGkA
Here is a short clip of the engine running on the dyno
https://www.youtube.com/watch?v=T75EW-_v3PE
I run a 4 speed with 4:10 on the rear so I can't help any with the converter but I am happy to share whatever I can about the build. My goal was to make a reliable driver with enough power to keep it fun.
