Lash Caps or Longer Valves? #1736111
01/22/15 02:30 AM
01/22/15 02:30 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
As part of the ongoing saga of my Edelbrock Victor MW heads I am trying to gain some installed height. I'd really like to use some lash caps and +.100 retainers instead of buying an entire set of valves. Can you guys help me with the pro's and con's of either choice? Obviously the valves would be way more expensive than the locks and caps. I'm all ears...
Re: Lash Caps or Longer Valves? [Re: Jeremiah] #1736112
01/22/15 03:06 AM
01/22/15 03:06 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
What is it you are trying to achieve. Do you "need" lash caps for rocker geometry............because just using a retainer and lock to increase installed height, doesn't mean you must use lash caps. I am sure you are also aware, that if you DO use a longer valve, it will alter rocker geometry and you might have to raise shafts and get a longer pushrod to correct it. If you have proper geometry now and pushrods, the obvious choice is +.050 locks and +.050 retainers.
Monte
Re: Lash Caps or Longer Valves? [Re: Monte_Smith] #1736113
01/22/15 03:17 AM
01/22/15 03:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte
What Monte said about the locks and retainers...
if your trying to just increase the install height..
of course if the geometry is fine now with the valve
length you have
Re: Lash Caps or Longer Valves? [Re: MR_P_BODY] #1736114
01/22/15 03:28 AM
01/22/15 03:28 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Manley offers +.100" retainers and a +.050" keeper , for a total of .150" more installed height if you need that much.....
Re: Lash Caps or Longer Valves? [Re: Monte_Smith] #1736115
01/22/15 03:59 AM
01/22/15 03:59 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Monte
Geometry-wise I am pretty happy with what I have but could add another .030 of shims if I went longer. I am already using a +.050 lock. If I could find a +.050 retainer in Super 7 that would be cool but so far no dice. I think it would have to be tool steel to not cause clearance issues with the rocker arm. I built a "test" cap to add .110 to the valve tip and added .030 to the .060 worth of shims I already had and the pattern was more than acceptable. I have been reading every catalog from Ferrea to Del West and my eyes are starting to cross. It gives you a new respect for guys that are making this stuff work with large-ish lift cams. I think the designer at Edelbrock forgot to account for the thickness of the spring seat/locator/cup and now it's haunting me. I wish I would have bought some -1's or MW EZ's at this point. Who designs a head with big flow potential and does not plan a 2" installed height for it?
Re: Lash Caps or Longer Valves? [Re: boatracer572] #1736116
01/22/15 04:04 AM
01/22/15 04:04 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
And I do need that much. With a .045 spring seat I am only seeing 1.920-30. Gaining .100 would be a blessing. From my measurements I would be lucky to get away with a +.050 retainer let alone a +.100. Thanks for the insight I might order some up anyway and have a look.
Re: Lash Caps or Longer Valves? [Re: Jeremiah] #1736117
01/22/15 12:50 PM
01/22/15 12:50 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Be advised that Manley +.100" retainers may not give you .100" more installed height.
2011 Drag Pak Challenger
Re: Lash Caps or Longer Valves? [Re: rickseeman] #1736118
01/22/15 01:00 PM
01/22/15 01:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What about cutting the seat ??
Re: Lash Caps or Longer Valves? [Re: rickseeman] #1736119
01/22/15 01:24 PM
01/22/15 01:24 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Good to know. I have a couple hundred dollars of retainers and locks to throw at this to figure it out. I'll make sure to report back with how it all measures up.
Re: Lash Caps or Longer Valves? [Re: Stanton] #1736120
01/22/15 01:24 PM
01/22/15 01:24 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Unfortunately there isn't enough meat due to the CNC porting done on the head.
Re: Lash Caps or Longer Valves? [Re: Jeremiah] #1736121
01/24/15 12:58 AM
01/24/15 12:58 AM
USA
B3RE Offline
B3RE  Offline
USA
Monte
I'll give you 500 bucks for them and you can apply that to a set of -1s. You'll have the heads you want, and I'll set up the Victors for a 540 I have with a .800" lift solid roller. Hey, I'm just trying to help you out.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Lash Caps or Longer Valves? [Re: Jeremiah] #1736122
01/24/15 02:27 AM
01/24/15 02:27 AM
Cab_Burge Online work
Cab_Burge  Online Work
I like and use lash caps on any serious solid lifter motor, especially solid roller lifter motors
Re: Lash Caps or Longer Valves? [Re: Cab_Burge] #1736123
01/24/15 03:03 AM
01/24/15 03:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm not a fan of lash caps on a engine.. I tend to
run high revs and never found it to be any help UNLESS
I was trying to correct a geometry issue of short valves..
yes the caps can help with a mushrooming issue... but
I have never had that.. thats with roller rockers on
a solid roller cam
Re: Lash Caps or Longer Valves? [Re: Jeremiah] #1736124
01/24/15 07:36 AM
01/24/15 07:36 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I hear you. Nice ports and can't fit a decent valve spring
My old heads, I cut the seat pockets, but they were stock ports. The CNC ported heads are ported about as tall as you can go before breaking into the valve spring seats. Anyone using a shim and no spring seat cup/locator? My old B-1 B/S heads were setup with just a shim between the spring and head so I'm not sure how important the spring cup/locator is?
Re: Lash Caps or Longer Valves? [Re: 451Mopar] #1736125
01/24/15 01:10 PM
01/24/15 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
After reading all of these hastles on these heads, I`ll probably go Indy through someone on here UNLESS those suck too then I`ll just stick w/my RPM`s and still have a solid 9-second car w/zero hastles and crazy cost.
Re: Lash Caps or Longer Valves? [Re: Thumperdart] #1736126
01/24/15 04:33 PM
01/24/15 04:33 PM
P
Porter67 Offline
Porter67  Offline
P
I myself like lash caps for two reasons, one is as mentioned to get the rocker arm geometry (scrub) where I like it and as well I feel they help spread the load on a small diameter stem. But im under 7400 rpm and something really bad would have to happen to toss a lash cap off.
Ive always had longer valves, as edelbrock seems to run a longer valve vs oem in the small block offering.
Ive recently found myself in a spot where I needed to use the smallest diameter spring I could find but with a high spring rate do to the amount of porting getting semi close to the spring pocket.
If I had not already had the setup id of went conical.
Re: Lash Caps or Longer Valves? [Re: B3RE] #1736127
01/24/15 05:06 PM
01/24/15 05:06 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Monte
Not just yet...I'm thinking some .060 and .090 rocker shaft spacers are going to be in order.
That said I'm going to do up a set of -1's with a paired rocker setup for my "good" motor.
Do you happen to be a Manley dealer? I'm going to start a database for installed height measurements of retainers and locks to get this stuff on paper for future builds. Apparently 451 and myself are the first guys around to try and use these heads to their potential.
Re: Lash Caps or Longer Valves? [Re: Thumperdart] #1736128
01/24/15 05:10 PM
01/24/15 05:10 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
MW EZ's all the way. Between the center rocker stand issue, installed height SNAFU, rocker to valve cover issues, headers hitting the valve cover, etc. it's not really worth the headache. Although some of those can be avoided by the user these problems should have been solved by an engineer.
Re: Lash Caps or Longer Valves? [Re: Jeremiah] #1736129
01/24/15 06:04 PM
01/24/15 06:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That may just be the ticket.............
Re: Lash Caps or Longer Valves? [Re: Jeremiah] #1736130
01/24/15 07:26 PM
01/24/15 07:26 PM
USA
B3RE Offline
B3RE  Offline
USA
No, I'm not a Manley dealer. I can get their whole line through one of my wholesale suppliers though.
Mike Beachel
