4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? #173539
12/23/08 06:02 PM
12/23/08 06:02 PM
Finally a HUSKER again
Moparnut426 Offline OP
Building my stroker combo, K1 crank, 4" stroke, 6.123 rods, main girdle. Will a factory windage tray work, if not what are you running??
Kasey
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: Moparnut426] #173540
12/23/08 06:09 PM
12/23/08 06:09 PM
Brunswick Ohio
dusta340 Offline
dusta340  Offline
Brunswick Ohio
by the time i cut it up to fit there was about nothing left and when i pulled it apart the next year the spot welds broke. i just ran with out one the milidon pan seems to be close so i didnt use one after that
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: dusta340] #173541
12/23/08 06:17 PM
12/23/08 06:17 PM
Im running an aluminum charlies pan, I just wanted to know what you guys are doing in that department.
Kasey
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: dusta340] #173542
12/23/08 06:19 PM
12/23/08 06:19 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
I run with out one in "El Picoso" as well.
Ted
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: Diego_Ted] #173543
12/23/08 06:22 PM
12/23/08 06:22 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I never run trays
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: RyanJ] #173544
12/23/08 09:36 PM
12/23/08 09:36 PM
408Dust Offline
408Dust  Offline
Don't need it...
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: 408Dust] #173545
12/23/08 10:12 PM
12/23/08 10:12 PM
I was told the Hughes stud girdle acts as a crank scraper.
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: Moparnut426] #173546
12/23/08 11:17 PM
12/23/08 11:17 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Kasey, if that Charlies pan has a screen in it & baffles like my Steffs pan, you don't need a windage tray.
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: b1dartsport] #173547
12/23/08 11:20 PM
12/23/08 11:20 PM
I dont think this pan did, That was my next question, can I add a screen in the pan?
Kasey
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: Moparnut426] #173548
12/24/08 04:21 PM
12/24/08 04:21 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Very few guys find any benefit in using a tray with an A engine. Crank scrapers are worth looking into, however.
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: BobR] #173549
12/24/08 06:14 PM
12/24/08 06:14 PM
I use crankshaft scrapers in any motor that will be RPM above 5000 RPM, street, strip or hauler A good, one way screen helps also, especially in the front of most pans(where they are shallow to clear the K members) so the oil won't bounce back up into the rotating assembly
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: Cab_Burge] #173550
12/24/08 06:24 PM
12/24/08 06:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Been told by the gurus for a long time, going back as far as McCandless, to not bother using one on a small block.
Rich H.
Esse Quam Videri
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: ZIPPY] #173551
12/24/08 06:32 PM
12/24/08 06:32 PM
, PA
sleepyhead416 Offline
, PA
I had 1 till I smashed the pan at PRP
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: sleepyhead416] #173552
12/25/08 12:59 AM
12/25/08 12:59 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
Are you running H-beam rods that yo don't have clearance? My I-beam stroker has lots of clearance.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY?? [Re: Moparnut426] #173553
12/25/08 12:53 PM
12/25/08 12:53 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
no tray required, the girdle will take care of it
