Re: 4" STROKE SMALL BLOCK, AND WINDAGE TRAY??
[Re: dusta340]
#173542
12/23/08 06:19 PM
12/23/08 06:19 PM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
by the time i cut it up to fit there was about nothing left and when i pulled it apart the next year the spot welds broke. i just ran with out one the milidon pan seems to be close so i didnt use one after that
I run with out one in "El Picoso" as well.
Ted
[Re: RyanJ]
#173544
12/23/08 09:36 PM
12/23/08 09:36 PM
Posts: 739 Florida
408Dust
[Re: BobR]
#173549
12/24/08 06:14 PM
12/24/08 06:14 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Very few guys find any benefit in using a tray with an A engine. Crank scrapers are worth looking into, however.
I use crankshaft scrapers in any motor that will be RPM above 5000 RPM, street, strip or hauler A good, one way screen helps also, especially in the front of most pans(where they are shallow to clear the K members) so the oil won't bounce back up into the rotating assembly
[Re: Cab_Burge]
#173550
12/24/08 06:24 PM
12/24/08 06:24 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
Been told by the gurus for a long time, going back as far as McCandless, to not bother using one on a small block.
Rich H.
Esse Quam Videri
