70 GTX A/C Removal #1734734
01/20/15 01:07 AM
01/20/15 01:07 AM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
I have a 70 GTX with AC. Currently not working so I want to remove the compressor until such time that I get around to replacing the compressor. When I take the compressor off will I need to change some pulleys for the power steering and alternator?
Thank you,
Joe
Re: 70 GTX A/C Removal [Re: joedee] #1734735
01/20/15 10:07 AM
01/20/15 10:07 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
It's hard to get anything at all lined up when you remove the compressor. Your best best bet will be to find a complete non ac pulley and bracket setup. Whatever you do, don't sell your oem ac stuff. You will never find the correct hoses.
Re: 70 GTX A/C Removal [Re: fastmark] #1734736
01/20/15 10:14 AM
01/20/15 10:14 AM
new york usa
P
pattyboy 572 Offline
P
new york usa
ASk me how i know...right mark...hows it going
Re: 70 GTX A/C Removal [Re: pattyboy 572] #1734737
01/20/15 11:36 AM
01/20/15 11:36 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Yes, you know from experience. Going great down here. Just about ready to fire up my 70. Have not restored the hose I have left so I hope it does not leak! I have not seen another one for sale since.
Re: 70 GTX A/C Removal [Re: joedee] #1734738
01/20/15 02:09 PM
01/20/15 02:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thank you,
Joe
power steering won't change as it doesn't run on the compressor , and there isn't a power steering pulley for A/C vs. non A/C. The only thing you would need to figure out is the altenator , but you can change the water pump pulley to the non AC and you should be able to run a belt with the existing lower pulley.
Re: 70 GTX A/C Removal [Re: JohnRR] #1734739
01/20/15 03:00 PM
01/20/15 03:00 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Thank you,
Joe
power steering won't cange as it doesn't run on the compressor , and there isn't a power steering pulley for A/c vs. non A/C , the only thing you would need to figure out is the altenator , but you can change the water pump pulley to the non AC and you should be able to run a belt with the existing lower pulley.
Ok thanks. I will get a non ac water pump pulley. And I am not going to sell the parts. Just keep them for when I get a new compressor.
Joe
Re: 70 GTX A/C Removal [Re: joedee] #1734740
01/20/15 05:02 PM
01/20/15 05:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you plan on replacing the compressor in the future why not just leave it there? When the A/C is off the compressor just acts as an idler pulley.
Re: 70 GTX A/C Removal [Re: John_Kunkel] #1734741
01/20/15 05:19 PM
01/20/15 05:19 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
This.
Kevin
Re: 70 GTX A/C Removal [Re: John_Kunkel] #1734742
01/20/15 05:23 PM
01/20/15 05:23 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I don't think the ac alt pulley and lower 4 groove pulley will line up with the single non ac pulley.
Re: 70 GTX A/C Removal [Re: fastmark] #1734743
01/20/15 06:57 PM
01/20/15 06:57 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
THEY WONT
5549 post on old board
Re: 70 GTX A/C Removal [Re: John_Kunkel] #1734744
01/21/15 04:49 PM
01/21/15 04:49 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Taking off because it is big and tired of the looks of it.
Joe
Re: 70 GTX A/C Removal [Re: joedee] #1734745
01/22/15 04:22 PM
01/22/15 04:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Somebody posted this pic of a compressor eliminator, don't know who makes it.
Re: 70 GTX A/C Removal [Re: John_Kunkel] #1734746
01/22/15 05:27 PM
01/22/15 05:27 PM
Waterloo, Wi
joedee Offline OP
joedee  Offline OP
Waterloo, Wi
Looks like 440 source sells the correct pulley for the non ac application.
Joe
Re: 70 GTX A/C Removal [Re: fastmark] #1734747
01/22/15 06:59 PM
01/22/15 06:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Correct , they won't
Re: 70 GTX A/C Removal [Re: joedee] #1734748
01/23/15 12:24 PM
01/23/15 12:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
taking the compressor off and just replace the water pump pulley isnt enough.
To get everything to line up.
yo have to replace the alternator brackets and spacers. upper AND lower pulleys.
Re: 70 GTX A/C Removal [Re: gtx6970] #1734749
01/23/15 01:34 PM
01/23/15 01:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You are right , I gave the OP the benifit of the doubt that when he took off the compressor and saw tha tthe altenator mounting point was gone that he would know he needed the non A/C Alt. mounting brackets.
I have run the dual pulley alt on a non A/C setup and don't remember throwing belts , but I will admit I haven't used the big ugly lower pulley.
But I have pulled motors from the junk yard that had the 4 groove pulley on them and didn't have the A/C setups still in place runing non A/C water pump and alt. setup ????
but you do this more than me ...
