White convertible top cleaning help needed.
#1733516
01/18/15 09:41 PM
01/18/15 09:41 PM
Posts: 493 Arizona
az426john
Arizona
A bird crapped on my white convertible top and I managed to get out all but a 1/16 inch yellow spot by using soap & water, tooth paste and a Mister Clean sponge. Does anyone have a suggestion on how to remove the last yellow spot without damaging the top? Thanks for your assistance in advance. John
Re: White convertible top cleaning help needed.
[Re: az426john]
#1733518
01/18/15 11:36 PM
01/18/15 11:36 PM
Posts: 12,165 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Soft Scrub with bleach. Just don't get it on anything that is not white. It will bleach a spot.
Master, again and still
[Re: az426john]
#1733521
01/20/15 01:59 AM
01/20/15 01:59 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Let the Soft Scrub sit there a couple of hours, keeping it damp and not letting it dry out. And it helps to scrub it ever so often while it is working.
If you find something that works better than anything else, let us know.
