White convertible top cleaning help needed. #1733516
01/18/15 09:41 PM
01/18/15 09:41 PM
Arizona
az426john Offline OP
Arizona
A bird crapped on my white convertible top and I managed to get out all but a 1/16 inch yellow spot by using soap & water, tooth paste and a Mister Clean sponge. Does anyone have a suggestion on how to remove the last yellow spot without damaging the top?
Thanks for your assistance in advance.
John
Re: White convertible top cleaning help needed. [Re: az426john] #1733517
01/18/15 11:06 PM
01/18/15 11:06 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Maybe try a little spray nine. I have used it on my white seat cushions. Magic eraser probably will take out the spot but I don`t know if it will damage the top or not.
Re: White convertible top cleaning help needed. [Re: az426john] #1733518
01/18/15 11:36 PM
01/18/15 11:36 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Soft Scrub with bleach. Just don't get it on anything that is not white. It will bleach a spot.
Master, again and still
Re: White convertible top cleaning help needed. [Re: DaveRS23] #1733519
01/19/15 06:31 PM
01/19/15 06:31 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I have used "Fantastic" on my 70 300Hurst ragtop . . . white top. Also on the white vinyl interior of my Duster360, spray it on, use a little scrub brush, and BAM, things look brand new again !!! I have a buddy that uses the Spray Nine . . . works about the same . . . good luck !!
Cheers
Mark
Re: White convertible top cleaning help needed. [Re: DaveRS23] #1733520
01/20/15 01:19 AM
01/20/15 01:19 AM
Arizona
Arizona
Many thanks for the prompt replies. I have tried the soft scrub with bleach and it did lighten it some, but it is still there. I will have to find some Nine and Fantastic and try them. Cross your fingers.
Thanks,
John
Re: White convertible top cleaning help needed. [Re: az426john] #1733521
01/20/15 01:59 AM
01/20/15 01:59 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Let the Soft Scrub sit there a couple of hours, keeping it damp and not letting it dry out. And it helps to scrub it ever so often while it is working.
If you find something that works better than anything else, let us know.
Re: White convertible top cleaning help needed. [Re: DaveRS23] #1733522
01/20/15 12:12 PM
01/20/15 12:12 PM
Arizona
Arizona
Thanks Dave....will do!
