Stripped acc pump screw holes-- helicoil? #1732717
01/18/15 04:06 AM
01/18/15 04:06 AM
State, country, etc.
gss Offline OP
gss  Offline OP
Has anyone had any luck repairing the threads for the accelerator pump? It's a Holley. Looks like they have been tapped to a 10-32 already. I think Holley makes a kit but it is $70 and i just need to fix one.
Re: Stripped acc pump screw holes-- helicoil? [Re: gss] #1732718
01/18/15 11:34 AM
01/18/15 11:34 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I bought a heli-coil kit for a #12-28 to fix the thread. But now I use a High Flow squirter screw for flow.
The existing design might have a groove machined parallel through the threads. This is how the squirter got the fuel. But the heli-coil covered up this groove so I went to a hollow screw.
Re: Stripped acc pump screw holes-- helicoil? [Re: YO7_A66] #1732719
01/18/15 11:54 AM
01/18/15 11:54 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I think the O.P. might be talking about the screws for the pump not the nozzle.
Re: Stripped acc pump screw holes-- helicoil? [Re: gss] #1732720
01/18/15 03:18 PM
01/18/15 03:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Unless it's a resto I would just buy a new bowl for about $50 and be done with it.
I really like the new sight glass bowl conversion so you never have to open fuel on a hot engine to set the levels
Linky
https://www.holley.com/products/fuel_sys...rts/parts/34-38
Gus
64 Plymouth Savoy
Dana 60
Re: Stripped acc pump screw holes-- helicoil? [Re: fourgearsavoy] #1732721
01/18/15 11:47 PM
01/18/15 11:47 PM
gss Offline OP
gss  Offline OP
Yes it is the pump diaphragm cover. This is the middle carb on my 6v intake. I can't find a new Holley 2300 fuel bowl and I really don't want a mismatched carb anyways. I'm wondering if they make a helicoil that fits it.
Re: Stripped acc pump screw holes-- helicoil? [Re: gss] #1732722
01/19/15 02:43 AM
01/19/15 02:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If the hole is too big already use a keensert, what size are the other screws ?
Re: Stripped acc pump screw holes-- helicoil? [Re: JohnRR] #1732723
01/19/15 03:17 AM
01/19/15 03:17 AM
gss Offline OP
gss  Offline OP
All four have already been drilled and tapped to 10-32.
Re: Stripped acc pump screw holes-- helicoil? [Re: gss] #1732724
01/19/15 08:06 PM
01/19/15 08:06 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
I know for a fact you can get Helicoil for 10-32 and for 8-32 as a mater of fact I have one here in my hands for 6-32 You can get the classic kit which will include the tap-drill bit- install tool and some coils. Look on amazon I fond them for under 30$ shipped.
Re: Stripped acc pump screw holes-- helicoil? [Re: mod5v] #1732725
01/20/15 02:52 AM
01/20/15 02:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sounds like he wants to restore the bowl to the original screw size which may not be 10-32 ?
We have helicoils at work down to 0-80 ...
Re: Stripped acc pump screw holes-- helicoil? [Re: JohnRR] #1732726
01/20/15 10:14 AM
01/20/15 10:14 AM
scratchnfotraction Offline
what carb? duel feed? I may have a bowl you can have.
Re: Stripped acc pump screw holes-- helicoil? [Re: scratchnfotraction] #1732727
01/20/15 11:19 AM
01/20/15 11:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's a 6pk center carb , they are a little different than a standard duel feed bowl.
Re: Stripped acc pump screw holes-- helicoil? [Re: JohnRR] #1732728
01/20/15 04:10 PM
01/20/15 04:10 PM
missed that part.
Re: Stripped acc pump screw holes-- helicoil? [Re: JohnRR] #1732729
01/21/15 02:36 AM
01/21/15 02:36 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
But it can be made to work and look identical !
Re: Stripped acc pump screw holes-- helicoil? [Re: 62maxwgn] #1732730
01/21/15 02:19 PM
01/21/15 02:19 PM
gss Offline OP
gss  Offline OP
Well I was able to get a bottom tap and make some good threads. Looks like whoever originally drilled and tapped for 10-32 screws used a taper or plug tap and didn't cut threads all the way down.
Re: Stripped acc pump screw holes-- helicoil? [Re: gss] #1732731
01/21/15 03:48 PM
01/21/15 03:48 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you ever get in a bind!
Re: Stripped acc pump screw holes-- helicoil? [Re: 62maxwgn] #1732732
01/21/15 11:56 PM
01/21/15 11:56 PM
gss Offline OP
gss  Offline OP
Thanks!
Re: Stripped acc pump screw holes-- helicoil? [Re: 62maxwgn] #1732733
01/22/15 09:44 AM
01/22/15 09:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes imagine that is possible for the 69 carb , but what aboutthe 70/with ECS and definitely the 71 ? Is there a generic double pumper bowl with the vent ?
Re: Stripped acc pump screw holes-- helicoil? [Re: JohnRR] #1732734
01/22/15 01:14 PM
01/22/15 01:14 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Yes imagine that is possible for the 69 carb , but what about the 70/with ECS and definitely the 71 ? Is there a generic double pumper bowl with the vent ?
Also 70 without ECS,as for the latter,I think that would be a "no" .
