Re: Stripped acc pump screw holes-- helicoil?
[Re: gss]
#1732718
01/18/15 11:34 AM
01/18/15 11:34 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I bought a heli-coil kit for a #12-28 to fix the thread. But now I use a High Flow squirter screw for flow. The existing design might have a groove machined parallel through the threads. This is how the squirter got the fuel. But the heli-coil covered up this groove so I went to a hollow screw.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: gss]
#1732720
01/18/15 03:18 PM
01/18/15 03:18 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Unless it's a resto I would just buy a new bowl for about $50 and be done with it. I really like the new sight glass bowl conversion so you never have to open fuel on a hot engine to set the levels Linky https://www.holley.com/products/fuel_sys...rts/parts/34-38Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: gss]
#1732722
01/19/15 02:43 AM
01/19/15 02:43 AM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
Yes it is the pump diaphragm cover. This is the middle carb on my 6v intake. I can't find a new Holley 2300 fuel bowl and I really don't want a mismatched carb anyways. I'm wondering if they make a helicoil that fits it.
If the hole is too big already use a keensert, what size are the other screws ?
[Re: mod5v]
#1732725
01/20/15 02:52 AM
01/20/15 02:52 AM
JohnRR
U.S.S.A.
All four have already been drilled and tapped to 10-32.
I know for a fact you can get Helicoil for 10-32 and for 8-32 as a mater of fact I have one here in my hands for 6-32 You can get the classic kit which will include the tap-drill bit- install tool and some coils. Look on amazon I fond them for under 30$ shipped.
Sounds like he wants to restore the bowl to the original screw size which may not be 10-32 ?
We have helicoils at work down to 0-80 ...
[Re: scratchnfotraction]
#1732727
01/20/15 11:19 AM
01/20/15 11:19 AM
JohnRR
U.S.S.A.
what carb? duel feed? I may have a bowl you can have.
It's a 6pk center carb , they are a little different than a standard duel feed bowl.
[Re: JohnRR]
#1732729
01/21/15 02:36 AM
01/21/15 02:36 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
But it can be made to work and look identical !
[Re: 62maxwgn]
#1732733
01/22/15 09:44 AM
01/22/15 09:44 AM
JohnRR
U.S.S.A.
Yes imagine that is possible for the 69 carb , but what aboutthe 70/with ECS and definitely the 71 ? Is there a generic double pumper bowl with the vent ?
[Re: JohnRR]
#1732734
01/22/15 01:14 PM
01/22/15 01:14 PM
62maxwgn
Blair County,PA
Yes imagine that is possible for the 69 carb , but what about the 70/with ECS and definitely the 71 ? Is there a generic double pumper bowl with the vent ?
Also 70 without ECS,as for the latter,I think that would be a "no" .
