NE1 mounted this alternator on a SB? #1732614
01/17/15 11:40 PM
01/17/15 11:40 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I was wondering if anyone has mounted this style of Desno alternator (91-93 Cherokee 90 amp) on an LA small block? Were you able to do it with stock brackets or modified stock brackets? Anyone know if there is a 2-groove v-belt pulley that will swap on? Photos?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: NE1 mounted this alternator on a SB? [Re: MadMatt] #1732615
01/18/15 11:22 AM
01/18/15 11:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have one on my Challenger. Stock brackets. I did grind on the case a little to clear the bottom bracket.You'll see what I mean when you mock it up.
Doug
Re: NE1 mounted this alternator on a SB? [Re: dvw] #1732616
01/18/15 01:22 PM
01/18/15 01:22 PM
scratchnfotraction Offline
I used this one on my 440 with stock non a/c brackets pullies.
external regulated using stock VR on firewall.
I flipped mine to move BATT stud away from head so I did not have to grind the stud down. (which seems needed on some apps)
got this off a van that still used external VR, crimped on eyeloops for field wires and trimed plastic off BATT wire so just the eyeloop was left to go into the shield on alt.
late 80s early 90s van and on the tbi 88-91 trucks
Re: NE1 mounted this alternator on a SB? [Re: scratchnfotraction] #1732617
01/18/15 01:54 PM
01/18/15 01:54 PM
came on a SB with this bracket pull set up.
Re: NE1 mounted this alternator on a SB? [Re: dvw] #1732618
01/18/15 04:36 PM
01/18/15 04:36 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Doug
Did it have the 2-groove pulley? Did you end up running the belt in the front or rear groove?
Thanks to everyone for all the info!
Re: NE1 mounted this alternator on a SB? [Re: MadMatt] #1732619
01/18/15 04:43 PM
01/18/15 04:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Single groove pulley. Don't know what it came off from. I went to my local auto parts where they rebuild alternators and just went through the pile. If it was a dual it would be on the inner pulley.
Doug
Re: NE1 mounted this alternator on a SB? [Re: dvw] #1732620
01/18/15 05:13 PM
01/18/15 05:13 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Doug
Thanks for the info. Guess I'll just have to try and grab one at the local bone yard and try and mock it up.
Re: NE1 mounted this alternator on a SB? [Re: MadMatt] #1732621
01/19/15 12:43 AM
01/19/15 12:43 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I used a tiny one from a Geo metro, I think its 35A but might be the same frame. Used a long ass lower timing cover bolt and a slant alternator bracket with a litte trimmming. I centered and welded the lower pulley off the metro to a damper bolt washer (both sides) and torqued it on, it aint moving.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: NE1 mounted this alternator on a SB? [Re: pishta] #1732622
01/19/15 12:54 AM
01/19/15 12:54 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I also run the little 35-45amp alternator. I seem to find it listed under a Suzuki Samurai. But I know I got it off a Chevy Nova (rebaged Geo) or Geo Metro in the junk yard.
Re: NE1 mounted this alternator on a SB? [Re: autoxcuda] #1732623
01/19/15 04:10 AM
01/19/15 04:10 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Id like to run the honker off my 06 minivan on something (emergency lawnmower generator?) but its got a bad decoupler on it and a ribbed pulley. wonder if I can swap the decoupler for a V pulley. its a 160A !
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: NE1 mounted this alternator on a SB? [Re: pishta] #1732624
01/19/15 11:21 AM
01/19/15 11:21 AM
are you wanting the 1 wire internal regulated alt or a external regulated denso alt?
the 88-89 trucks/vans have the v groove pullys and work with the stock VR on the car or truck.
the 1 wire alt needs a little more to work, needs the 2 wire plug and a extra wire/larger BATT wire. IIRC.
you may be able to find an alt shop/rebuilder local that can swap the pully out for a v-groove.
I have a local rebuilder that has everything to rebuild the mini alt/starters for 65$
Re: NE1 mounted this alternator on a SB? [Re: MadMatt] #1732625
01/21/15 03:18 AM
01/21/15 03:18 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
What I'm after is more output, especially at idle, because I'm upgrading to FAST EZ-EFI 2.0 with an in-tank pump. I want to stick with the stock external voltage regulator, and I'm hoping for minimal mods to the existing brackets, pulleys, etc.
Re: NE1 mounted this alternator on a SB? [Re: scratchnfotraction] #1732626
01/21/15 11:47 PM
01/21/15 11:47 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Scratchin'
Did you happen to weigh the alternator you used? How does it compare to the late 60's, early 70's mopar factory alternator?
Re: NE1 mounted this alternator on a SB? [Re: davenc] #1732627
01/22/15 02:10 AM
01/22/15 02:10 AM
Western Md.
skicker Online tonguue
"The Champ"
skicker  Online Tonguue
"The Champ"
Western Md.
Whatever you decide to go with watch out for the one wire alternators. I run them on both of my cars...neither charges at idle, but they work fine for everything else. I used the chrome one that Summit sells...can't remember the name...
...FAFO...
Re: NE1 mounted this alternator on a SB? [Re: davenc] #1732628
01/22/15 10:07 AM
01/22/15 10:07 AM
Scratchin'
the small one on my 88 truck is about 1/2 the weight. the one in the pic off 440 is a 120 amp denso and is the same or a little less best guess.
PM me I have some on the shelf I will scale for you
