NE1 mounted this alternator on a SB?
#1732614
01/17/15 11:40 PM
01/17/15 11:40 PM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
I was wondering if anyone has mounted this style of Desno alternator (91-93 Cherokee 90 amp) on an LA small block? Were you able to do it with stock brackets or modified stock brackets? Anyone know if there is a 2-groove v-belt pulley that will swap on? Photos?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: NE1 mounted this alternator on a SB?
[Re: dvw]
#1732616
01/18/15 01:22 PM
01/18/15 01:22 PM
Posts: 15,487 Florida
scratchnfotraction
I used this one on my 440 with stock non a/c brackets pullies. external regulated using stock VR on firewall. I flipped mine to move BATT stud away from head so I did not have to grind the stud down. (which seems needed on some apps) got this off a van that still used external VR, crimped on eyeloops for field wires and trimed plastic off BATT wire so just the eyeloop was left to go into the shield on alt. late 80s early 90s van and on the tbi 88-91 trucks
[Re: autoxcuda]
#1732623
01/19/15 04:10 AM
01/19/15 04:10 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
Id like to run the honker off my 06 minivan on something (emergency lawnmower generator?) but its got a bad decoupler on it and a ribbed pulley. wonder if I can swap the decoupler for a V pulley. its a 160A !
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: MadMatt]
#1732625
01/21/15 03:18 AM
01/21/15 03:18 AM
MadMatt
Nampa, ID
What I'm after is more output, especially at idle, because I'm upgrading to FAST EZ-EFI 2.0 with an in-tank pump. I want to stick with the stock external voltage regulator, and I'm hoping for minimal mods to the existing brackets, pulleys, etc.
[Re: davenc]
#1732628
01/22/15 10:07 AM
01/22/15 10:07 AM
scratchnfotraction
Scratchin'
Did you happen to weigh the alternator you used? How does it compare to the late 60's, early 70's mopar factory alternator?
the small one on my 88 truck is about 1/2 the weight. the one in the pic off 440 is a 120 amp denso and is the same or a little less best guess.
PM me I have some on the shelf I will scale for you
