Need help troubleshooting MSD ignition *Problem solved* #1732344
01/17/15 06:58 PM
01/17/15 06:58 PM
Tampa
DusterDave Offline OP
Tampa
I installed an MSD Digital 6AL and an MSD Pro Billet distributor in my stroker 318/390 Jeep project, and I don't have spark at the plugs. I'm posting this here, because its a performance type ignition system. I did the test recommended by MSD, where you touch the green and violet wires with a paper clip, and I got spark out of the coil. Problem is, I don't get any spark at the plugs when turning the engine over. I've checked and rechecked all my wiring. All my power and ground wires were checked with a multimeter. I even went and bought another box, just to rule that out!!
I've run out of things to check, and I'm pretty aggravated at this point. Any advice is welcome.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Need help troubleshooting MSD ignition [Re: DusterDave] #1732345
01/17/15 07:04 PM
01/17/15 07:04 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
Did you adjust the setting for an 8 cylinder motor? also another thing to check is did you cut the wire as per instructions? I don't remember off the top of my head what color it is but it will be a small looped wire.
Re: Need help troubleshooting MSD ignition [Re: DusterDave] #1732346
01/17/15 07:11 PM
01/17/15 07:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you jump the crank and run wires out of the ignition
switch so its hot all the time the key is on.. and
did you eliminate the ballast
Re: Need help troubleshooting MSD ignition [Re: grncpe] #1732347
01/17/15 07:16 PM
01/17/15 07:16 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What dist? If it is a new MP unit, check the pick up air gap. If not, check it anyway. DAMHIK.
Kevin
Re: Need help troubleshooting MSD ignition [Re: Twostick] #1732348
01/17/15 07:17 PM
01/17/15 07:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kevin
Says its a MSD dist
EDIT
But jumping the wires like he did is just by-passing
the dist pick up.. so the pick up can still be bad
Re: Need help troubleshooting MSD ignition [Re: DusterDave] #1732349
01/17/15 07:24 PM
01/17/15 07:24 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Have you tried tried switching the polarity of the pickup wires?
I ran into a similar problem last year. I did all the same checks and rechecks you did, no dice.
Posted the problem here and Bob George said to try that. I didn't really even understand what he was referring to at first but then I went back and re-read it. I went out and tried it and voila! Car started right up.
MSD actually makes a note of it in the instructions.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Need help troubleshooting MSD ignition [Re: DusterDave] #1732350
01/17/15 08:00 PM
01/17/15 08:00 PM
central il.
second 70 Offline
second 70  Offline
central il.
As Mr. P said You have to tie the starter wire and ignition wire together. If you check you will find the ignition wire is hot when the key is in run position and not the start position.
Re: Need help troubleshooting MSD ignition [Re: second 70] #1732351
01/17/15 10:40 PM
01/17/15 10:40 PM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
Not to be a smarta$$ but did you put the rotor on? Don't ask me how I know!
Re: Need help troubleshooting MSD ignition [Re: urdustd] #1732352
01/17/15 10:43 PM
01/17/15 10:43 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
lol i was going to say the same thing .
Re: Need help troubleshooting MSD ignition [Re: urdustd] #1732353
01/17/15 10:44 PM
01/17/15 10:44 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Have you tried selling it and buying a system that works?
Re: Need help troubleshooting MSD ignition [Re: second 70] #1732354
01/18/15 02:25 AM
01/18/15 02:25 AM
Tampa
Tampa
Ding ding ding! We have a winner! One of the wires for ignition 12v was on the wrong terminal on the ignition switch! Problem corrected and she's running now! Thanks to all who offered advice!
