72 360 head ID #1732207
01/17/15 04:18 PM
01/17/15 04:18 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
I have a 72 motorhome 360, 2 barrel. The casting number on the heads is 34189156. I found the number 3418915, which says it's a 71-2 360 head, but I can't find any with the extra 6 on the end. Would these be "j" heads? Thanks.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 72 360 head ID [Re: GTSDart340] #1732208
01/17/15 04:21 PM
01/17/15 04:21 PM
is that number a 3418915-6.
Re: 72 360 head ID [Re: RapidRobert] #1732209
01/17/15 04:22 PM
01/17/15 04:22 PM
Laveen, Arizona
Laveen, Arizona
Its hard to tell, as the engine is still together. It probably is. It's in a shed, so it's kinda difficult to get to.
Re: 72 360 head ID [Re: GTSDart340] #1732210
01/17/15 05:54 PM
01/17/15 05:54 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Probably just a J head with 1.88 intake valves
Re: 72 360 head ID [Re: GTSDart340] #1732211
01/17/15 11:41 PM
01/17/15 11:41 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Yep, 915 J heads. Note the big "J" in the casting below; there should also be one on the outside between the spark plug holes. Don't be surprised if they're cracked.
Re: 72 360 head ID [Re: vdriver] #1732212
01/20/15 04:06 PM
01/20/15 04:06 PM
dogdays Offline
dogdays  Offline
Yeah, it's a "magical" J head, pull'em and sell to some fool who thinks they are trick. They were used on 340s back in the day, so they have street cred. The fact that Mopar engines many times used exact same components across the performance range seems to have escaped the hoi polloi.
R.
Re: 72 360 head ID [Re: dogdays] #1732213
01/20/15 04:21 PM
01/20/15 04:21 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
R.
...FAFO...
Re: 72 360 head ID [Re: skicker] #1732214
01/20/15 04:31 PM
01/20/15 04:31 PM
Hamtramck, PA
Alaskan_TA Online content
Fluffy Balladeer
Alaskan_TA  Online Content
Fluffy Balladeer
Hamtramck, PA
The 915 castings can be J, O, U or Z heads, the letter itself means nothing.
Re: 72 360 head ID [Re: Alaskan_TA] #1732215
01/20/15 05:32 PM
01/20/15 05:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
And the 915 casting can have 2.02 or 1.88" intake valves, the number means little in and of itself.
Don't be the exception.
Re: 72 360 head ID [Re: Supercuda] #1732216
01/20/15 05:33 PM
01/20/15 05:33 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
They can also be T/A heads.
The 915s were pretty popular.
Re: 72 360 head ID [Re: dogdays] #1732217
01/20/15 05:56 PM
01/20/15 05:56 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
R.
And if they had an "X" on them people lose their minds. They open their wallets and send all logic and reason out the window.
Re: 72 360 head ID [Re: Leadfoot] #1732218
01/20/15 09:38 PM
01/20/15 09:38 PM
Laveen, Arizona
Laveen, Arizona
They are going to be used on my 408 project, at least until I can afford some aluminum heads. I will put the 2.02 valves in them.
Re: 72 360 head ID [Re: GTSDart340] #1732219
01/21/15 02:51 PM
01/21/15 02:51 PM
dogdays Offline
dogdays  Offline
I believe there are several articles floating around on productive modifications to the intake ports and it is possible to get 250cfm from them with basic porting.
I'd more suggest you use the $ you would have spent on the larger valves and put it towards porting and a competition valve job. There's more hp in that.
R.
Re: 72 360 head ID [Re: Alaskan_TA] #1732220
01/21/15 05:06 PM
01/21/15 05:06 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
If I am remembering right I have a "I" head and a "II" head on my 360 at least between the spark plugs. Regular big J underneath both.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: 72 360 head ID [Re: Michael Ecks] #1732221
01/21/15 07:34 PM
01/21/15 07:34 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
What do you want more low end torque or top end. If you want more low end I know some circle track guys that have gone back to the 1.88 valve over the 2.02 and have gained a lot of low end coming out of the turns. Personally I switched from 1.88 to 2.02 and gained absolutely nothing when I had my duster. Both set had the same cut to the same CC other than that were in stock form.
Re: 72 360 head ID [Re: MoparforLife] #1732222
01/21/15 08:12 PM
01/21/15 08:12 PM
Laveen, Arizona
Laveen, Arizona
It's going to be a mostly street but occasionally strip car. I want it (68 Dart) to be able to take down a 69 Skylark with a 455... So I'm looking at low 12s high 11s. I want it on the edge of being legal without a cage. At this point, it's all in the planning stage. Thanks guys!
