How much motor do i need? #1731394
01/16/15 04:30 PM
01/16/15 04:30 PM
Pound, Va
Chris Vanover Offline OP
Pound, Va
I want to run at least 4.80 to 4.70s with my car. It is a 240in single shock swing arm dragster. My current motor is a 500in rb motor with out of the box 440-1's on alky and indy block, 13.2 compression. It has run a 5.601 in really good air and typically 5.72-5.75 in my 2660lb door car. Im thinking my dragster weighs around 1850 race cars as it is now with a bbc motor in it. It's a 525 with pro comp heads and a gm truck block its ran a 4.92.
What will the car run just by putting my current combo in it?
Can i get to where i want to go with taking my motor to a 572 or 588? I would raise the compression, have the heads ported and bigger valves put in the heads i have now. untill i can buy some bigger heads.
Thanks,
Chris
Re: How much motor do i need? [Re: Chris Vanover] #1731395
01/16/15 05:14 PM
01/16/15 05:14 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Talk to Al Alguire
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: How much motor do i need? [Re: Chris Vanover] #1731396
01/16/15 06:22 PM
01/16/15 06:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you put the car engine in the dragster you will
need about 200hp more.... if thats what I think your
trying to do(car engine in dragster)
Re: How much motor do i need? [Re: Chris Vanover] #1731397
01/16/15 07:17 PM
01/16/15 07:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW our Racetech was running low 5.o's(7.90's) at about 1870 with a 557" CNC -1 combo here in Vegas. Was a pretty basic combo til it blew up Motor going in will be a 446 with -1 heads. Will let you know how that one runs.
Re: How much motor do i need? [Re: Al_Alguire] #1731398
01/16/15 07:57 PM
01/16/15 07:57 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Drop the compression and put an F2 on it....Done.
Re: How much motor do i need? [Re: Dragula] #1731399
01/17/15 02:06 AM
01/17/15 02:06 AM
Pound, Va
Pound, Va
I have thought of the pro charged deal. Would probably go with a f1-x rather then the f2. The f1-x is a little more adjustable then the f2 from what i can see from buddies cars. I have a buddy with a f2 on a 565 and runs low 4.30's turned all the way down Then a buddy with a 540 with a f1-x that runs 4.4's on a easy tune and can turn it down more if needed. It also went a 4.27 with the same settings down in the carolina's in better air.
Its only money, i just need to make more of it to do so lol
Re: How much motor do i need? [Re: Chris Vanover] #1731400
01/17/15 12:13 PM
01/17/15 12:13 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
B1 originals fully ported, biggish cam, 572 CI, 15-1 compression, and hold on. If it's built right it should make 1000+ and go 4.60's-4.70's at sea level all day long at 7500 RPM.
Re: How much motor do i need? [Re: Chris Vanover] #1731401
01/17/15 12:31 PM
01/17/15 12:31 PM
ky
68roadrunner Offline
ky
my 499 with 325cc -1 in my 1850lb undercover went 5.00 to 5.10
just put my 557 world aluminum block with the same heads on and a bigger cam is going 4.78-79 in fall air in ky. havent weighed it but it should weigh 1750 now. only have 35 passes on it so far, it may have a little more in it with some tune but i doubt much.
hope this helps
Re: How much motor do i need? [Re: camastomcat] #1731402
01/17/15 12:33 PM
01/17/15 12:33 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Oh, I'm pretty sure 572-13's would get the same result if you talk to Todd Marsh. He's done some stout builds with them.
Re: How much motor do i need? [Re: camastomcat] #1731403
01/17/15 12:48 PM
01/17/15 12:48 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
My low deck 540 with -1s .701 .663 cam on alcohol ran 4.70s and 7.60s @ 1700#
Re: How much motor do i need? [Re: camastomcat] #1731404
01/17/15 12:50 PM
01/17/15 12:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW what I posted above was in Vegas at altitude. SO figure .2 quicker at sea level at least. We have no barometer up here.
Re: How much motor do i need? [Re: evenflow] #1731405
01/17/15 12:57 PM
01/17/15 12:57 PM
ky
ky
wondering what port size in your heads or maybe the cam is better than mine for it to be quicker with less motor
