64 DODGE 880, WHAT REAR END B OR C BODY?
#1730816
01/15/15 06:44 PM
01/15/15 06:44 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Which 8 3/4 rear will work in a 64 880 custom. Friend wants to shed the taperd axle and go with a conventional rear. Will one from a 68 to 70 b body bolt up? Also is this a B or C body car? Thanks In advance
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 64 DODGE 880, WHAT REAR END B OR C BODY?
[Re: mikeysmopars]
#1730817
01/15/15 07:04 PM
01/15/15 07:04 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You need one with 46" spring centers which is C or E-body. E-body has the wrong pinion angle so a '65-'69 C-body would be the best fit.
[Re: dogdays]
#1730819
01/15/15 07:23 PM
01/15/15 07:23 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
IIRC they made them a bit wider than the kids 62 300 was.We did fit a 69 C body under his 62.He used the offset hanger and it fit well.Then he used my 65 B body and was a straight sweap.The 64 should use a later c body as I believe they were wide for the 880 which was a full size.Plymouths were termed mid size .Rocky
Chrysler Firepower
[Re: DoctorDiff]
#1730829
01/17/15 02:57 PM
01/17/15 02:57 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Pretty reasonable considering what you get.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: John_Kunkel]
#1730831
01/17/15 09:13 PM
01/17/15 09:13 PM
Centerline
Texas Hill Country
Also, the tapered axles were strong enough for the max wedge cars and they'll hold up to just about anything under 500 horses.
Every serious racer carried a spare set of axle keys.
Touché. Always a smart move.
Point is for street duty, typical stoplight to stoplight stuff, the original tapered axles are more than up to the task. A simple (under $100) mod makes them totally serviceable with modern brake drums that slip on just as the '65 and later diffs do. However, if you want to do some serious racing or you're running upwards of 500 ponies on the street, an upgrade would probably be a good idea.
