440 fuel pump push rod...4th post #172979
12/22/08 06:07 PM
12/22/08 06:07 PM
Riyadh, Saudi Arabia
Merlin45 Offline OP
Merlin45  Offline OP
Hello all. I've done some calling and info collecting on my fuel pump push rod. My cam is a billet cam shaft, that's why I need to use a "brass" tip fuel pump push rod. Yes, from talking to a part seller they are a wearable item (I had no idea, someone also pointed this out). Seems several of you have had some push rods that have lasted for a long time in the engine. Racepumps.com tech said their brass tips are of a different metal combo, are harder and wear better and work on billet cams. May go that route and see how their product wears. I'm still working the issue, just want to be sure I get a quality part in to alleviate un-necessary fuel pump removals over time as well as protecting my cam and using the correct part. Any more info would be greatly appreciated. Thanks!
Re: 440 fuel pump push rod...4th post [Re: Merlin45] #172980
12/22/08 06:22 PM
12/22/08 06:22 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
billet cam? so that means you have a roller tappet cam?
Re: 440 fuel pump push rod...4th post [Re: lewtot184] #172981
12/23/08 08:43 AM
12/23/08 08:43 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This is getting to be a spamish post...Run an electric and be done with it!!!!!!!
Re: 440 fuel pump push rod...4th post [Re: Merlin45] #172982
12/23/08 09:05 AM
12/23/08 09:05 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Never heard of running a "brass tip" fuel pump push rod. Nor have I ever had an isue w/ a stock on wearing out. If this is for a "race" application you should probably re-post this in the race section. The company you bought the cam form should be able to give you any info you need to complete your build. FWIW most of the guys I know that run roller cams run electric pumps, but then agaiin they are pretty much race car that see limited street use.
Re: 440 fuel pump push rod...4th post [Re: Mr.Yuck] #172983
12/23/08 09:54 AM
12/23/08 09:54 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
bronze tip for billet, iron tip for cast iron.
Re: 440 fuel pump push rod...4th post [Re: lewtot184] #172984
12/23/08 11:36 AM
12/23/08 11:36 AM
I noticed that Mancini now has a brass(tipped) one for a roller cam. Only $69.95. Dont forget your discount code
Re: 440 fuel pump push rod...4th post [Re: RapidRobert] #172985
12/23/08 01:29 PM
12/23/08 01:29 PM
Kirkland, Washington
Pacnorthcuda Offline
$70 for a fuel pump rod??? Wow---that bites!
Re: 440 fuel pump push rod...4th post [Re: Pacnorthcuda] #172986
12/23/08 01:43 PM
12/23/08 01:43 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Actually very common especially now a days with the crappy china steel.
Re: 440 fuel pump push rod...4th post [Re: mopars4ever] #172987
12/23/08 05:56 PM
12/23/08 05:56 PM
I,m running one from "Racepumps", with a Crane hydraulic roller, no problems so far.
Re: 440 fuel pump push rod...4th post [Re: Pacnorthcuda] #172988
12/23/08 09:56 PM
12/23/08 09:56 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
That's a good chunk of money towards a good electric.
