M/T Sportmans #172957
12/22/08 05:53 PM
12/22/08 05:53 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
There not radials so whats a good cheap tire i can run up front with these things?
Re: M/T Sportmans [Re: midnite360] #172958
12/22/08 06:06 PM
12/22/08 06:06 PM
Richmond, VA
VT_Dart Offline
VT_Dart  Offline
Richmond, VA
I ran both the bias ply fronts and radial fronts and actually had MUCH better handling with the radial fronts. I know they say not to mismatch radial and bias ply, but the car was much more predictable easy to drive with the radials. Many will argue and I understand their reasoning, but that was just my personal experience.
Darrah Heath
Re: M/T Sportmans [Re: VT_Dart] #172959
12/23/08 11:05 AM
12/23/08 11:05 AM
scratchnfotraction Offline
you should not mix the 2 on the same axle,IMO
I run 29x15.5x15 on a 12" rim with 165/15 on a 3 1/2"x15 rim on a 85 step side truck with no probs
I also run some 235/15 on 7" rims on the front with no probs
M/T has a wide sreet radial tire also thats new
you could run some front runners from micky to matcha sportsman
IMO,they dont wear that good for street driving.for the front
my sportsmans are holding up good to daily driving and has been 1 1/2yrs now,reg street tire on the front
run em!
Re: M/T Sportmans [Re: scratchnfotraction] #172960
12/23/08 09:15 PM
12/23/08 09:15 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
run em!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: M/T Sportmans [Re: BloFish] #172961
12/24/08 07:35 AM
12/24/08 07:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run Mickeys on the rear and I have a set of Nexen and a set of Kumho 165 80 15s for the fronts.Its street driven and handles well.Rocky
Chrysler Firepower
Re: M/T Sportmans [Re: VT_Dart] #172962
12/25/08 10:54 PM
12/25/08 10:54 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I've driven quite a few M/T Sportsman cars with the same setup.
Front and rear tires aren't on "the same axle", I think they mean the same car...?
Hate to say it, but I've never had issues.
CrAzYMoPaRGuY
Re: M/T Sportmans [Re: CrAzYMoPaRGuY] #172963
12/25/08 11:49 PM
12/25/08 11:49 PM
Back in the day guys to cheap to buy matching sets of rubber would put whatever they had on any wheel. Sometimes they would put bias-ply and radial tires on the same axle. Seeing as how they grip differently they would get bad results.
If you run mickey's on the rear and radials on the front you shouldn't have any issues.
Re: M/T Sportmans #172964
12/26/08 07:23 AM
12/26/08 07:23 AM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
I had a 74 roadrunner way back when and tried the radials-frong and bias-back, scary handling. I had M/T sportsman fronts on my duster for a while. Absolutely hated them. Car felt like it had 250,000 miles on the front end parts. Constantly fighting the steering wheel. Put some Kumho radials on the front and now it drives like it should.
