sb dist, ????
#172871
12/22/08 12:49 PM
12/22/08 12:49 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
HI all, I have a dist ? my old 360 combo had a MP dist modified bt don at FBO, it only has amech advance no vac. After speaking to don about my new 410 stroker combo( same cam,carb,intake,heads and headers) he suggested to send it back to be recurved and vac advance added. Well that sounds great but i cant see spending more $$$ on this old mp dist, if i new what to change i would. anyway i was searching e-gag and found these two dist.. can the advance be adjusted easy? can the caps be changed with a mopar (female) cap? anyone use these dist? I am also looking at the digital dist as well, but thats a lot of $$$ tell me what you think? http://cgi.ebay.com/ebaymotors/DISTRIBUT...sQ5fAccessories$85 http://cgi.ebay.com/ebaymotors/MOPAR-DOD...sQ5fAccessories$67 here is my combo if needed 72 360 stroked to 410 10.2 cr ported J heads w/2.02 crosswinds intake (rpm air gap) holley 770 carb long tube header 2500-2800 stall XE274H comp cam 230/236@488/491 lift 904 auto 3.73 gears 96 dakota
Re: sb dist, ????
[Re: Dakota_Don]
#172874
12/22/08 01:43 PM
12/22/08 01:43 PM
RapidRobert
Don my suggestion would be to use your old dist as is for the time being since $$$ are tight. I'd set your total at ~35 which since you have already set the curve will make your initial come out pretty good like it did on the previous eng. If it's not pinging no damage is being done only that there would be some additional power to be gained if you can advance it more & still have no ping. This way you can experiment with it until you can afford to get a vac adv unit.
