Smothing out firewall #172810
12/22/08 07:45 AM
12/22/08 07:45 AM
Martinez, California
Challenged Offline OP
Hello, I would like to smooth out the firewall in my 72 Challenger. I have seen where others have covered the existing firewall with another layer of metal. I would do this but am concerned about rust developing between them. What would be the best product to put on the panels before joining them? Is their a better way besides out and replacing the firewall? If anybody has done this could you send me some pictures? Thanks.....Ed
Re: Smothing out firewall [Re: Challenged] #172811
12/22/08 08:48 AM
12/22/08 08:48 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Coat them with weld through primer or butt weld them instead of lapping them.
Re: Smothing out firewall [Re: Challenged] #172812
12/22/08 10:05 AM
12/22/08 10:05 AM
Jacksonville Florida
elitecustombody Offline
cut the old one out,as Adam mentionned,use weld thru primer and butt weld,if you end up keeping the old firewall behind the new sheetmetal,spray lots of etching primer in all the holes,once finished and painted spray 3M Rust Fighter
http://store.goferauto.com/083mrufi1834.html
but I would just trim the old wall out
Stefan
Re: Smothing out firewall [Re: elitecustombody] #172813
12/22/08 11:18 AM
12/22/08 11:18 AM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
It may be possible to leave the existing firewall intack, and attach the new "firewall" to the original firewall with hidden fasteners so it could be removed periodically for cleaning, checking for rust, or any other reason. I remember seeing this done on a car years ago....but I don't recall exactly how the new firewall was attached.
Re: Smothing out firewall [Re: Challenged] #172814
12/26/08 12:04 PM
12/26/08 12:04 PM
Thanks for the help. I will proceed with caution. Regards.....Ed
Re: Smothing out firewall [Re: Challenged] #172815
12/26/08 05:48 PM
12/26/08 05:48 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
Cutting it out is the best way or make sheetmetal patches over the holes you dont want/need.
Cut the whole thing out on my Demon, moved everything under the dash. There was some weight savings as well as the clean look
Old pic..
