Rear Window Gaskets Club Cab where to get? #1727976
01/12/15 02:26 PM
01/12/15 02:26 PM
Germany
1964Polara Offline OP
Germany
I need for a 1979 Club Cab the window gaskets for the rear (side) windows. Whats the correct name and where can I get some???
Many thanx
Re: Rear Window Gaskets Club Cab where to get? [Re: 1964Polara] #1727977
01/14/15 06:07 AM
01/14/15 06:07 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Would have thought JC Whitney or Precision Restoration Parts, but I couldn't verify. You might try contacting them and if they don't make/sell them, maybe they might know who does.
Re: Rear Window Gaskets Club Cab where to get? [Re: 1964Polara] #1727978
01/15/15 09:11 PM
01/15/15 09:11 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Think I got mine from the dealer for a 90's Club Cab. But that was almost 20 years ago.
Re: Rear Window Gaskets Club Cab where to get? [Re: redraptor] #1727979
01/16/15 12:23 PM
01/16/15 12:23 PM
Amarillo, Tx
ramblebee Offline
ramblebee  Offline
Amarillo, Tx
I ended up going to boneyard and pulling glass from a 92 club cab with the moveable flip open windows. I used the hinges,latches and weather strip from the donor truck. I struck out completely on gaskets for the fixed type glass.
Re: Rear Window Gaskets Club Cab where to get? [Re: ramblebee] #1727980
01/16/15 03:52 PM
01/16/15 03:52 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Several venders (like JC Whitney and most rubber suppliers) offer generic window rubber. You basically get a rubber form with a cross section that is close to what was originally on your vehicle and buy the rubber in lengths, by the foot, cut to fit, and super glue the ends together. To determine what cross section pattern you need, cut across (90 degrees to the run length) your existing rubber in a location that is still good, and match up your cross section with the existing options they have pictured, measure for the length of the rubber you need, and order it. They may not be "factory" and they may not be perfect on sharp bends, but they can be made to work. Street rod people have done this for years. The next option is to have a larger piece of glass cut (I suggest you make a plywood pattern for the new glass) and have the larger piece of glass bonded to your pinch welds. Gene
Re: Rear Window Gaskets Club Cab where to get? [Re: poorboy] #1727981
01/17/15 04:45 AM
01/17/15 04:45 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Bone yard is the way to go.
Re: Rear Window Gaskets Club Cab where to get? [Re: 77ProStreet] #1727982
01/18/15 12:25 PM
01/18/15 12:25 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
So you can replace your 30+ year old rubber gaskets with other 30+ year old rubber gaskets? You understand that rubber deteriorates with time, right? Gene
