Engine wiring harness differences? #1726613
01/10/15 08:11 PM
01/10/15 08:11 PM
St Louis, Missouri
Runnin74 Offline OP
Runnin74  Offline OP
St Louis, Missouri
Anyone know the physical wiring differences in the engine wiring harnesses for small blocks with 50, 60, or 85 amp alternators?
Re: Engine wiring harness differences? [Re: Runnin74] #1726614
01/10/15 11:36 PM
01/10/15 11:36 PM
Pretty sure they were all the same. I can't see why they would have made different harness' for a different alternator output. Why not just make one harness for the biggest output alternator since that would be the most cost efficient.
Re: Engine wiring harness differences? [Re: ] #1726615
01/11/15 12:12 AM
01/11/15 12:12 AM
St Louis, Missouri
Runnin74 Offline OP
Runnin74  Offline OP
St Louis, Missouri
That's my impression as well, although the harness part numbers are broken down by engine and alternator amperage. Just wondered if anyone had noticed any physical wiring differences.
Re: Engine wiring harness differences? [Re: Runnin74] #1726616
01/11/15 01:44 AM
01/11/15 01:44 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
In the mid 70s, 60 amp alternators in B body cars, especially in police and taxi packages, were wired to the ammeter through a grommet in the firewall instead of the bulkhead connector. That was the only difference. Check FSMs from 1973 and 1974 for Satellite 60 amp alternator wiring.
Craig
Re: Engine wiring harness differences? [Re: Runnin74] #1726617
01/11/15 10:57 AM
01/11/15 10:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What year are you talking about ? I don't think there was an 85 amp option in the muscle car era.
Re: Engine wiring harness differences? [Re: JohnRR] #1726618
01/11/15 01:49 PM
01/11/15 01:49 PM
St Louis, Missouri
Runnin74 Offline OP
Runnin74  Offline OP
St Louis, Missouri
I'm looking at 74. An 85amp L/N (Leece-Neville) or 86amp Motorola were available as well as a 65amp heavy duty w/batt isolation (presumably the grommet Craig mentioned above)in addition to the 50 and 60 amp alternators.
I have an engine harness from a 70 truck and the alternator wire is much larger than the car examples I have even though it has the same connector at the bulkhead disconect that cars use.
