"Premium" Spectra Gas Tanks #1725637
01/09/15 02:52 PM
01/09/15 02:52 PM
Northeast
V
VincentVega Offline OP
V
Northeast
I'm very close to buying a CR21A Spectra fuel tank
I don't know what this means: "Ni-terne plated steel gas tank"
I'm concerned about the bare/bright finish of these things. has anyone used one of these tanks for several years? do they rust quick? is it worth scuffing and painting? Sure would be nice to have something bolt right in for $300.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725638
01/09/15 02:54 PM
01/09/15 02:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It what the factory used to plate tanks and keep them from rusting.
Don't be the exception.
Re: "Premium" Spectra Gas Tanks [Re: Supercuda] #1725639
01/09/15 03:01 PM
01/09/15 03:01 PM
Northeast
V
V
Northeast
I didn't know that, thanks.
hmmm, methinks a liberal spray of undercoating
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725640
01/09/15 03:04 PM
01/09/15 03:04 PM
dogdays Offline
dogdays  Offline
"Spectra Premium" is AFAIK the name of the company.
http://www.spectrapremium.com/home.html
I've never had a gas tank rust out from the outside.
R.
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725641
01/09/15 03:25 PM
01/09/15 03:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not sure about the coating your asking about but we prefer and have used a lot of their tanks with ZERO issues
Re: "Premium" Spectra Gas Tanks [Re: TJP] #1725642
01/09/15 03:29 PM
01/09/15 03:29 PM
Northeast
V
V
Northeast
Thanks!
Re: "Premium" Spectra Gas Tanks [Re: TJP] #1725643
01/09/15 03:31 PM
01/09/15 03:31 PM
dogdays Offline
dogdays  Offline
Be aware also that a lot of people sell these on ebay and prices can be quite reasonable. Also if you're ordering from a parts store check out all the major parts vendors. On their radiators I have found a big difference between say Autozone and OReilly's, and also Rockauto.
They have a nice electronic catalog that you can access from their home page that I posted above.
R.
Re: "Premium" Spectra Gas Tanks [Re: dogdays] #1725644
01/09/15 03:33 PM
01/09/15 03:33 PM
Northeast
V
V
Northeast
Thank you. Cheapest I've found so far is on ebay for 279 + 30 shipping. For some reason this is probably the most expensive tank they make. Rockauto is $300 clean, and I love dealing with them. I wish they still did the 10% discounts.
My father just picked up one of those stainless 62 B body tanks on Ebay, which I showed him half an hour ago after I learned about them on this forum
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725645
01/09/15 04:14 PM
01/09/15 04:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Don't sand the tank unless you want to remove the anti rust coating. I haven't used a couple of their tanks with zero issues.
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725646
01/09/15 04:31 PM
01/09/15 04:31 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm a 74 B body owner. Got that tank back in 2008 straight from Krammer in Carlisle. So far so good, still looks perfect nowdays ( my car use to be a driver, but has being under body job last year )
the only "bad" I could advertise is the sender ring retainer assembly. The piece welded to the tank is kinda weak and bends easilly trying to lock the ring.
Yes they can be found on ebay under $300 easily. maybe around $270 las time I checked. I got it in $240 or so, and on those years they were also on $400 rate like today from regular vendors
Re: "Premium" Spectra Gas Tanks [Re: NachoRT74] #1725647
01/09/15 04:37 PM
01/09/15 04:37 PM
Northeast
V
V
Northeast
Thanks! That is great info. I now remember reading something similar somewhere else about that fragile aspect of it. Still, I'd rather not go with a fuel cell. thanks again
Oh that reminds me, if anyone cares, these fit all the way up to 1978 B body. I had one from a 74 satellite in my 78 with dual exhaust, fits fine, hump and all. I think the difference in application is something to do with the vapor and emissions system, but it worked fine that way as well.
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725648
01/09/15 04:55 PM
01/09/15 04:55 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
If anyone cares, Ni-terne is a combination of Nickle and Terne plate finish. Terne is a combination of Lead and Tin but with the environmental issues related to lead, Terne II is now the norm which is a combination of Zinc and Tin.
...no, don't sand it and it will last a loooooooong time without any additional coating.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: "Premium" Spectra Gas Tanks [Re: DPelletier] #1725649
01/09/15 04:57 PM
01/09/15 04:57 PM
Northeast
V
V
Northeast
Thanks, Dave.
I just ordered one. I really would like to undercoat it, though. Any tips on that? Wipe with cleaner and go?
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725650
01/09/15 06:10 PM
01/09/15 06:10 PM
DPelletier Offline
DPelletier  Offline
You'll need to wipe it down with a good solvent or wash with degreaser to remove the oil from the manufacturing process.
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725651
01/10/15 06:37 AM
01/10/15 06:37 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
If a car has been parked for a few years, that's likely the reason the old gas tank rusted out.
As stated above, metal gas tanks fail by rusting from the inside due to trapped moisture, not from the outside. Moisture accumulates inside typically because the car has been permanently parked or seldom driven. Driving the car should consume moisture along with the gasoline and help prevent failure of the inside coating. With or without undercoating a new terne tank should last as long as the car is driven regularly.
Terne sheet is steel sheet that has been hot dipped in solder at the steel mill. And that's what the original assembly line tanks were made of. And the factory tanks were almost never undercoated, because there was no need.
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725652
01/10/15 01:35 PM
01/10/15 01:35 PM
Same here I've used several spectra (Canadian?) tanks & no problems. I dont remember if it had that ni-tern coating or not. I did undercoat em. Eastwood & others I'm sure offer coatings for the inside but I'd be leery of that, if a person did that, then the prep (just like any type of painting) would have to be spot on so it would never come off. Keeping the tank filled is always a good plan
Re: "Premium" Spectra Gas Tanks [Re: RapidRobert] #1725653
01/10/15 03:53 PM
01/10/15 03:53 PM
Northeast
V
V
Northeast
No, I won't use the internal coatings anymore. We did that on my old tank for the same car, and on another car. They both failed after a number of years. Peeled and cracked like a parched desert floor, got particles up into the fuel system and the carb as well we think. Nice idea, but hydrocarbons are a tough thing to resist.
I'm really talking about the outside. I've seen factory undercoated tanks from the early 60s and they're still "mint" to steal a David Freiburgerism.
I like Rustoleum and they have a roller-on rubberized undercoat I'm considering
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725654
01/10/15 05:48 PM
01/10/15 05:48 PM
yes you were clear about that, it was me, I was off on a tangent (been doing that alot lately). I'm a firm believer in a new/clean tank and getting the pickup horizontle and just off the bottom (water etc settles lowest) and tossing the sock for a perf app and soldering in a bung for plumbing the fuel & keeping the OE 5/16" pickup just so the gauge reads correct as the aftermarket 3/8 ones are reportedly mostly bad (dont read right) or drilling out a good 5/16 pickup & adding a 3/8 line (flange the flat circular metal piece that the line goes thru)
Re: "Premium" Spectra Gas Tanks [Re: RapidRobert] #1725655
01/10/15 05:55 PM
01/10/15 05:55 PM
Northeast
V
V
Northeast
Really? I didn't know that. I had a good 3/8 pickup for my tank and fuel varnish ruined it. Been on the lookout for one with the return nipple as well but that's been more of a backburner item.
Re: "Premium" Spectra Gas Tanks [Re: VincentVega] #1725656
01/10/15 05:59 PM
01/10/15 05:59 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Please don't ruin a perfectly new tank with undercoat or anything else for that matter.
Is this a hobby car or a daily driver?
Ron
