"Premium" Spectra Gas Tanks
#1725637
01/09/15 02:52 PM
01/09/15 02:52 PM
Posts: 1,106 Northeast
VincentVega
Northeast
I'm very close to buying a CR21A Spectra fuel tank
I don't know what this means: "Ni-terne plated steel gas tank"
I'm concerned about the bare/bright finish of these things. has anyone used one of these tanks for several years? do they rust quick? is it worth scuffing and painting? Sure would be nice to have something bolt right in for $300.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: "Premium" Spectra Gas Tanks
[Re: Supercuda]
#1725639
01/09/15 03:01 PM
01/09/15 03:01 PM
VincentVega
Northeast
I didn't know that, thanks. hmmm, methinks a liberal spray of undercoating
[Re: VincentVega]
#1725640
01/09/15 03:04 PM
01/09/15 03:04 PM
dogdays
"Spectra Premium" is AFAIK the name of the company. http://www.spectrapremium.com/home.htmlI've never had a gas tank rust out from the outside. R.
[Re: dogdays]
#1725644
01/09/15 03:33 PM
01/09/15 03:33 PM
VincentVega
Northeast
Thank you. Cheapest I've found so far is on ebay for 279 + 30 shipping. For some reason this is probably the most expensive tank they make. Rockauto is $300 clean, and I love dealing with them. I wish they still did the 10% discounts.
My father just picked up one of those stainless 62 B body tanks on Ebay, which I showed him half an hour ago after I learned about them on this forum
[Re: NachoRT74]
#1725647
01/09/15 04:37 PM
01/09/15 04:37 PM
VincentVega
Northeast
Thanks! That is great info. I now remember reading something similar somewhere else about that fragile aspect of it. Still, I'd rather not go with a fuel cell. thanks again
Oh that reminds me, if anyone cares, these fit all the way up to 1978 B body. I had one from a 74 satellite in my 78 with dual exhaust, fits fine, hump and all. I think the difference in application is something to do with the vapor and emissions system, but it worked fine that way as well.
[Re: VincentVega]
#1725648
01/09/15 04:55 PM
01/09/15 04:55 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
If anyone cares, Ni-terne is a combination of Nickle and Terne plate finish. Terne is a combination of Lead and Tin but with the environmental issues related to lead, Terne II is now the norm which is a combination of Zinc and Tin.
...no, don't sand it and it will last a loooooooong time without any additional coating.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1725649
01/09/15 04:57 PM
01/09/15 04:57 PM
VincentVega
Northeast
Thanks, Dave.
I just ordered one. I really would like to undercoat it, though. Any tips on that? Wipe with cleaner and go?
[Re: VincentVega]
#1725650
01/09/15 06:10 PM
01/09/15 06:10 PM
DPelletier
You'll need to wipe it down with a good solvent or wash with degreaser to remove the oil from the manufacturing process.
1974 'Cuda
[Re: VincentVega]
#1725651
01/10/15 06:37 AM
01/10/15 06:37 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
If a car has been parked for a few years, that's likely the reason the old gas tank rusted out.
As stated above, metal gas tanks fail by rusting from the inside due to trapped moisture, not from the outside. Moisture accumulates inside typically because the car has been permanently parked or seldom driven. Driving the car should consume moisture along with the gasoline and help prevent failure of the inside coating. With or without undercoating a new terne tank should last as long as the car is driven regularly.
Terne sheet is steel sheet that has been hot dipped in solder at the steel mill. And that's what the original assembly line tanks were made of. And the factory tanks were almost never undercoated, because there was no need.
[Re: VincentVega]
#1725652
01/10/15 01:35 PM
01/10/15 01:35 PM
RapidRobert
Same here I've used several spectra (Canadian?) tanks & no problems. I dont remember if it had that ni-tern coating or not. I did undercoat em. Eastwood & others I'm sure offer coatings for the inside but I'd be leery of that, if a person did that, then the prep (just like any type of painting) would have to be spot on so it would never come off. Keeping the tank filled is always a good plan
[Re: RapidRobert]
#1725653
01/10/15 03:53 PM
01/10/15 03:53 PM
VincentVega
Northeast
No, I won't use the internal coatings anymore. We did that on my old tank for the same car, and on another car. They both failed after a number of years. Peeled and cracked like a parched desert floor, got particles up into the fuel system and the carb as well we think. Nice idea, but hydrocarbons are a tough thing to resist.
I'm really talking about the outside. I've seen factory undercoated tanks from the early 60s and they're still "mint" to steal a David Freiburgerism.
I like Rustoleum and they have a roller-on rubberized undercoat I'm considering
[Re: RapidRobert]
#1725655
01/10/15 05:55 PM
01/10/15 05:55 PM
VincentVega
Northeast
Really? I didn't know that. I had a good 3/8 pickup for my tank and fuel varnish ruined it. Been on the lookout for one with the return nipple as well but that's been more of a backburner item.
