lets talk about sliders versus shackles #172530
12/21/08 07:21 PM
12/21/08 07:21 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I am currently changing springs on the rear of my car and was considering going to sliders instead of the old shackles.Are they really that much better?
Gus
64 Plymouth Savoy
Dana 60
Re: lets talk about sliders versus shackles [Re: fourgearsavoy] #172531
12/21/08 07:44 PM
12/21/08 07:44 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I put them on mine when I moved the springs into the frame rails. It allows it to sit 1/2 to 3/4" lower in the rear which is what I wanted. Only difference I noticed is on the street they pop at times when I turn sharp but I have a Dana with a spool. If you install them make sure to have the slide bolt set 3/4 of the way to the rear with the weight of the car on them or they will bottom out during the launch as the spring arches.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: lets talk about sliders versus shackles [Re: 67HEMI] #172532
12/21/08 08:19 PM
12/21/08 08:19 PM
Rittman Ohio
Rittman Ohio
Yeah thats the project I am doing(moving the springs in) and I had to do something with the rear half.I was concerned about the amount of travel because I still drive my car to the track.I was looking at the ones Mancini sells where did you get yours?
Gus
64 Plymouth Savoy
Dana 60
Re: lets talk about sliders versus shackles [Re: fourgearsavoy] #172533
12/23/08 10:26 AM
12/23/08 10:26 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Anybody else? I have been thinking about switching to them also
One day I will have something cool here.
Re: lets talk about sliders versus shackles [Re: sdaurity] #172534
12/23/08 12:27 PM
12/23/08 12:27 PM
San Diego
formula S Offline
formula S  Offline
San Diego
I'm not sure how long the slot is in these sliders are, but if they ever bottom out the slot during chassis rise, the spring becomes solid and will unload the rear tire, much like having rear shocks that are to short
Re: lets talk about sliders versus shackles [Re: formula S] #172535
12/23/08 12:48 PM
12/23/08 12:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is true but this is also where good shocks come
in to play. The reason I dont care for sliders is
that if they get dirt and crap into them they can
and will bind up throwing the chassis off
Re: lets talk about sliders versus shackles [Re: formula S] #172536
12/23/08 07:28 PM
12/23/08 07:28 PM
Rittman Ohio
Rittman Ohio
Thats the one point that has me questioning my decision.I am also looking at the Afco single adjustable shocks with with the new high velocity rebound valving.
Gus
64 Plymouth Savoy
Dana 60
Re: lets talk about sliders versus shackles [Re: fourgearsavoy] #172537
12/23/08 08:05 PM
12/23/08 08:05 PM
Ma
Voluster Offline
Voluster  Offline
Ma
I have them in my car
Put them in this year
Didn't notice any difference other then lowering the car in the rear
Re: lets talk about sliders versus shackles [Re: fourgearsavoy] #172538
12/23/08 10:03 PM
12/23/08 10:03 PM
67HEMI Offline
67HEMI  Offline
I got mine from summit. They are Afco's. I have monoleaf cal trac springs,cal-trac bars,single adjustable rancho shocks. Best 60 ft 1.47 on drag radials @ 3850 lbs.
Re: lets talk about sliders versus shackles [Re: formula S] #172539
12/23/08 10:07 PM
12/23/08 10:07 PM
67HEMI Offline
67HEMI  Offline
The slot is around 4 inches,maybe longer, I think. Mine have never bottomed out on compression or rise.
Re: lets talk about sliders versus shackles [Re: fourgearsavoy] #172540
12/23/08 10:07 PM
12/23/08 10:07 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Gus
Shackles work great I see these sliders as a gimmick, something different, save your money. BTW what suspension are you running?
Re: lets talk about sliders versus shackles [Re: fourgearsavoy] #172541
12/24/08 12:16 AM
12/24/08 12:16 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Sliders may help in some combos, and are high techno looking. But shackles really work just fine, IMO and are also better in some/Most combos. But there are the exceptions!
Whats your combo needing IYO, mike
Re: lets talk about sliders versus shackles [Re: formula S] #172542
12/24/08 04:51 PM
12/24/08 04:51 PM
Rittman Ohio
Rittman Ohio
My current setup is 456-457 SS springs,Procomp truck shocks and snubber.I had Cal-Tracs and Monoleafs but they went flat just like the 3400 springs did.I really liked the way the Cal-Tracs hooked and launched but for a street strip car they were not the solution.I now have a pair of 454-455 3800# springs to install and I was going to install them with "good" Afco adjustable shocks and move them inboard to the framerails.This is the reason for the sliders instead of installing upper spring mounts in the frame.
Gus
64 Plymouth Savoy
Dana 60
Re: lets talk about sliders versus shackles [Re: fourgearsavoy] #172543
12/25/08 09:44 AM
12/25/08 09:44 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
Gus
I believe AFCO makes them :
http://www.afcoracing.com/tech_pages/leaf.shtml
Take a look at speedway motors. There's both a standard and a heavy duty part :
http://www.speedwaymotors.com/Heavy-Duty-Leaf-Spring-Sliders,5817.html
http://www.speedwaymotors.com/Leaf-Spring-Sliders,2151.html
Re: lets talk about sliders versus shackles [Re: fourgearsavoy] #172544
12/25/08 11:14 AM
12/25/08 11:14 AM
ct
jkgtx Offline
jkgtx  Offline
ct
I used the afco sliders for two years
average 60ft 1.52 I liked them because it lowered
the car with the ss springs.wasnt very happy with the cars being consistant,made my own 4 link with ladderbar brackets and coilovers 1.46 60ft
with no other changes
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
Re: lets talk about sliders versus shackles [Re: jkgtx] #172545
12/25/08 12:04 PM
12/25/08 12:04 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
The sliders were designed for circle track cars so I really dont see how they are a gimmick
The vid below is from norwalk and this guy swears by them, as do the guys from AFCO.
http://www.youtube.com/watch?v=vOLyjoARD...=1&index=81
IMO
Re: lets talk about sliders versus shackles [Re: joshking440] #172546
12/25/08 11:00 PM
12/25/08 11:00 PM
Rittman Ohio
Rittman Ohio
Well I think I will buy a pair of the HD units from Speedway and build my own brackets with 2 extra inches of travel in the slots.Too bad I will have to wait sooo long to see if they work.Its going to be one of those years where everything is different except the transmission and rear end.
Gus
64 Plymouth Savoy
Dana 60
