lets talk about sliders versus shackles
#172530
12/21/08 07:21 PM
12/21/08 07:21 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I am currently changing springs on the rear of my car and was considering going to sliders instead of the old shackles.Are they really that much better? Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: lets talk about sliders versus shackles
[Re: fourgearsavoy]
#172531
12/21/08 07:44 PM
12/21/08 07:44 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I put them on mine when I moved the springs into the frame rails. It allows it to sit 1/2 to 3/4" lower in the rear which is what I wanted. Only difference I noticed is on the street they pop at times when I turn sharp but I have a Dana with a spool. If you install them make sure to have the slide bolt set 3/4 of the way to the rear with the weight of the car on them or they will bottom out during the launch as the spring arches.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#172532
12/21/08 08:19 PM
12/21/08 08:19 PM
fourgearsavoy
Rittman Ohio
Yeah thats the project I am doing(moving the springs in) and I had to do something with the rear half.I was concerned about the amount of travel because I still drive my car to the track.I was looking at the ones Mancini sells where did you get yours? Gus ![](/ubbthreads/images/graemlins/beer.gif)
[Re: formula S]
#172535
12/23/08 12:48 PM
12/23/08 12:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm not sure how long the slot is in these sliders are, but if they ever bottom out the slot during chassis rise, the spring becomes solid and will unload the rear tire, much like having rear shocks that are to short
This is true but this is also where good shocks come in to play. The reason I dont care for sliders is that if they get dirt and crap into them they can and will bind up throwing the chassis off ![](/ubbthreads/images/graemlins/wave.gif)
[Re: fourgearsavoy]
#172538
12/23/08 10:03 PM
12/23/08 10:03 PM
67HEMI
I got mine from summit. They are Afco's. I have monoleaf cal trac springs,cal-trac bars,single adjustable rancho shocks. Best 60 ft 1.47 on drag radials @ 3850 lbs.
[Re: fourgearsavoy]
#172540
12/23/08 10:07 PM
12/23/08 10:07 PM
Posts: 660 San Diego
formula S
San Diego
Thats the one point that has me questioning my decision.I am also looking at the Afco single adjustable shocks with with the new high velocity rebound valving. ![](/ubbthreads/images/graemlins/shruggy.gif) Gus
Shackles work great I see these sliders as a gimmick, something different, save your money. BTW what suspension are you running?
[Re: formula S]
#172542
12/24/08 04:51 PM
12/24/08 04:51 PM
fourgearsavoy
Rittman Ohio
My current setup is 456-457 SS springs,Procomp truck shocks and snubber.I had Cal-Tracs and Monoleafs but they went flat just like the 3400 springs did.I really liked the way the Cal-Tracs hooked and launched but for a street strip car they were not the solution.I now have a pair of 454-455 3800# springs to install and I was going to install them with "good" Afco adjustable shocks and move them inboard to the framerails.This is the reason for the sliders instead of installing upper spring mounts in the frame. Gus ![](/ubbthreads/images/graemlins/beer.gif)
[Re: fourgearsavoy]
#172544
12/25/08 11:14 AM
12/25/08 11:14 AM
Posts: 622 ct
jkgtx
ct
I used the afco sliders for two years average 60ft 1.52 I liked them because it lowered the car with the ss springs.wasnt very happy with the cars being consistant,made my own 4 link with ladderbar brackets and coilovers 1.46 60ft with no other changes ![](/ubbthreads/images/graemlins/grin.gif)
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
[Re: jkgtx]
#172545
12/25/08 12:04 PM
12/25/08 12:04 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
The sliders were designed for circle track cars so I really dont see how they are a gimmick The vid below is from norwalk and this guy swears by them, as do the guys from AFCO. http://www.youtube.com/watch?v=vOLyjoARD...=1&index=81IMO
[Re: joshking440]
#172546
12/25/08 11:00 PM
12/25/08 11:00 PM
fourgearsavoy
Rittman Ohio
Well I think I will buy a pair of the HD units from Speedway and build my own brackets with 2 extra inches of travel in the slots.Too bad I will have to wait sooo long to see if they work.Its going to be one of those years where everything is different except the transmission and rear end. Gus ![](/ubbthreads/images/graemlins/beer.gif)
