Re: Vacume pump users, do you see water vapor?
[Re: Cab_Burge]
#1724387
01/07/15 10:55 PM
01/07/15 10:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You will see condensation in the tank.. thats normal EDIT I pick up the vac from the valve cover right over the second rocker hold down with a good baffle.. I made up a interlocking U with a top that I weld to the VC
[Re: dvw]
#1724392
01/08/15 12:57 AM
01/08/15 12:57 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yes I see vapor on mine. I pick up my reading from the back of a valve cover.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: rebel]
#1724394
01/08/15 07:42 AM
01/08/15 07:42 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Some moisture is common.
The less vacuum leaks you have the less moisture you get in my experience.
[Re: 1967dartgt]
#1724395
01/08/15 11:00 AM
01/08/15 11:00 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Same here.
[Re: MR_P_BODY]
#1724399
01/08/15 12:43 PM
01/08/15 12:43 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
MrCab I see water vapor(moisture)on 1st crank after setting from one week to the next also.
I try and put the hose for my vacuum gauge on one side and pull vacuum and the pop off valve on the other side.If I mount the vacuum pump on the drivers side I like to pull vacuum from the passenger side,I do not think it really matters but find it's best that way to help keep it from spraying a fine mist of oil out the top of the filter when its at max pressure.
PS If I run one off another Big Block Mopar engine with the valley plate like Indy,I will pull vacuum from it as close to the center as I can get.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1724400
01/08/15 12:53 PM
01/08/15 12:53 PM
MR_P_BODY
You get moisture all the time BUT you just pump it out due to the engine being warm.... the air going into the engine is carrying the moisture in
[Re: MR_P_BODY]
#1724401
01/08/15 12:58 PM
01/08/15 12:58 PM
MRMOPAR622
Sweet Home Alabama
When you drain your vacuum tank you will also find a small amount of water the 1st time and this is normal.On an alcohol engine you will find even more water. PS there is no need to worry about forgetting to drain your tank.If you do it will remind you when it needs draining! I have the Wife save the small butter bowls to drain mine in.I like to leave my pit space as clean as it is when I get there.At the end of the day you can put the lid back on it and duct tape it and put it in the trash can.Some may say not to put it in there but I say thats better than draining it on the ground.
[Re: MRMOPAR622]
#1724402
01/08/15 01:03 PM
01/08/15 01:03 PM
MR_P_BODY
Sure.. alky engines(fuel) absorbs water so when its heated it separates... same with E-85.. so you have 2 sources of moisture being carried into the engine
[Re: Forest]
#1724404
01/08/15 06:13 PM
01/08/15 06:13 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
Moisture is normal for me too...you can see my vacuum line fitting in the valley plate.
anybody else notice how nice this engine and set up looks? sorry. didn't mean to get off of the topic but i had to give a shout out to this. now back to your regularly scheduled program.
[Re: 9secondsatellite]
#1724405
01/08/15 06:18 PM
01/08/15 06:18 PM
MR_P_BODY
It IS PRETTY... one thing... that vac line sure is small... we are playing with a FAIR bit of volume
