ebody 3.91s always on fender tag?
#1723598
01/06/15 11:57 PM
01/06/15 11:57 PM
Posts: 54 US
BLACK71
US
Wondering if they were always on the tag as an axle package or was it possible to get them without the code
RMNS 10:9-10
Re: ebody 3.91s always on fender tag?
[Re: mopar346]
#1723601
01/07/15 01:36 AM
01/07/15 01:36 AM
Posts: 5,268 NY
70440+6bbl
NY
All though the 26 inch radiator is coded the 3.91 would not be or at least not on my AAR or any other I've seen for that matter.
AARs and TAs only came with 3.55 or 3.91 axle ratios and both those gears required the 26" radiator. You only find the gear ratio for those two cars on the original paperwork (BS, window sticker, etc). Otherwise, the code A31 or A36 will be coded on the tag.
[Re: 70440+6bbl]
#1723602
01/07/15 01:40 AM
01/07/15 01:40 AM
Posts: 5,268 NY
70440+6bbl
NY
[Re: 70440+6bbl]
#1723603
01/07/15 01:44 AM
01/07/15 01:44 AM
Posts: 5,268 NY
70440+6bbl
NY
[Re: 70440+6bbl]
#1723604
01/07/15 01:48 AM
01/07/15 01:48 AM
Posts: 5,268 NY
70440+6bbl
NY
[Re: BLACK71]
#1723606
01/07/15 01:58 AM
01/07/15 01:58 AM
Posts: 5,268 NY
70440+6bbl
NY
Your car would have had the 3.23 gears, if there is no axle pkg coded on the tag.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 70440+6bbl]
#1723608
01/07/15 02:06 AM
01/07/15 02:06 AM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
Your car (A66 Challenger) would have had the 3.23 gears, if there is no axle pkg coded on the tag.
[Re: BLACK71]
#1723610
01/07/15 06:00 PM
01/07/15 06:00 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Be happy that on the E body the gear change was an Axle package and there was a code.
On the 69 A bodies (also Hamtramack built) built with a performance axle ratio there was no code so the only way to know is with factory/dealer documentation.
[Re: JohnRR]
#1723612
01/07/15 07:45 PM
01/07/15 07:45 PM
Posts: 5,268 NY
70440+6bbl
NY
On the 67-69 A bodies (also Hamtramack built) built with a performance axle ratio there was no code so the only way to know is with factory/dealer documentation.
Yup, and that's because the A-body kept the same radiator support regardless of the gears. I believe it was the same way for the '70-71 A-bodies as well.
[Re: mccannix]
#1723613
01/08/15 01:17 PM
01/08/15 01:17 PM
JohnRR
U.S.S.A.
Dont 68 A-body fender tags have the numbers under the AX ? Number under A indicating ratio, 4= 3:23 in this case, 8 under X = suregrip. 6 would be 3:55 7 would be 3:91 9 would be 4:10 ..or so I always thought
You are correct , I forgot about the changed layout ... should have just kept to what I know ... 69 ...
