ebody 3.91s always on fender tag? #1723598
01/06/15 11:57 PM
01/06/15 11:57 PM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
Wondering if they were always on the tag as an axle package or was it possible to get them without the code
RMNS 10:9-10
Re: ebody 3.91s always on fender tag? [Re: BLACK71] #1723599
01/07/15 12:24 AM
01/07/15 12:24 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
They will be coded on the tag since it was a package and had an impact on the body in white (26" radiator support).
Re: ebody 3.91s always on fender tag? [Re: 70440+6bbl] #1723600
01/07/15 01:26 AM
01/07/15 01:26 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
All though the 26 inch radiator is coded the 3.91 would not be or at least not on my AAR or any other I've seen for that matter.
Careful, your character's showing!
Re: ebody 3.91s always on fender tag? [Re: mopar346] #1723601
01/07/15 01:36 AM
01/07/15 01:36 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
AARs and TAs only came with 3.55 or 3.91 axle ratios and both those gears required the 26" radiator. You only find the gear ratio for those two cars on the original paperwork (BS, window sticker, etc). Otherwise, the code A31 or A36 will be coded on the tag.
Re: ebody 3.91s always on fender tag? [Re: 70440+6bbl] #1723602
01/07/15 01:40 AM
01/07/15 01:40 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
another
Re: ebody 3.91s always on fender tag? [Re: 70440+6bbl] #1723603
01/07/15 01:44 AM
01/07/15 01:44 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Another 3.55
Re: ebody 3.91s always on fender tag? [Re: 70440+6bbl] #1723604
01/07/15 01:48 AM
01/07/15 01:48 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
1971 cuda 3.91
Re: ebody 3.91s always on fender tag? [Re: 70440+6bbl] #1723605
01/07/15 01:54 AM
01/07/15 01:54 AM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
My a66 challenger currently has 3.23s in it.. LA built car, so no BS just wondering if there were any lower gear options for it that weren't coded as an axle package
Re: ebody 3.91s always on fender tag? [Re: BLACK71] #1723606
01/07/15 01:58 AM
01/07/15 01:58 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Your car would have had the 3.23 gears, if there is no axle pkg coded on the tag.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: ebody 3.91s always on fender tag? [Re: 70440+6bbl] #1723607
01/07/15 02:02 AM
01/07/15 02:02 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Neat car
Re: ebody 3.91s always on fender tag? [Re: 70440+6bbl] #1723608
01/07/15 02:06 AM
01/07/15 02:06 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Your car (A66 Challenger) would have had the 3.23 gears, if there is no axle pkg coded on the tag.
Re: ebody 3.91s always on fender tag? [Re: 6bblgt] #1723609
01/07/15 02:33 AM
01/07/15 02:33 AM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
Yeah with everything else as original as it is on this car I figured the 3.23s were the standard gear, just wondering about any leeway from the factory without tag codes
Re: ebody 3.91s always on fender tag? [Re: BLACK71] #1723610
01/07/15 06:00 PM
01/07/15 06:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Be happy that on the E body the gear change was an Axle package and there was a code.
On the 69 A bodies (also Hamtramack built) built with a performance axle ratio there was no code so the only way to know is with factory/dealer documentation.
Re: ebody 3.91s always on fender tag? [Re: JohnRR] #1723611
01/07/15 07:12 PM
01/07/15 07:12 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Dont 68 A-body fender tags have the numbers under the AX ?
Number under A indicating ratio, 4= 3:23 in this case,
8 under X = suregrip.
6 would be 3:55
7 would be 3:91
9 would be 4:10
..or so I always thought
Re: ebody 3.91s always on fender tag? [Re: JohnRR] #1723612
01/07/15 07:45 PM
01/07/15 07:45 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
On the 67-69 A bodies (also Hamtramack built) built with a performance axle ratio there was no code so the only way to know is with factory/dealer documentation.
Yup, and that's because the A-body kept the same radiator support regardless of the gears. I believe it was the same way for the '70-71 A-bodies as well.
Re: ebody 3.91s always on fender tag? [Re: mccannix] #1723613
01/08/15 01:17 PM
01/08/15 01:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
6 would be 3:55
7 would be 3:91
9 would be 4:10
You are correct , I forgot about the changed layout ... should have just kept to what I know ... 69 ...
