2000 ram van trans problem #1723236
01/06/15 02:02 PM
01/06/15 02:02 PM
Frederick , MD
GibW340 Offline OP
GibW340  Offline OP
Frederick , MD
My 2000 ram van left me stranded- tran workied fine- stopped at a light , when accelerated out felt sluggish- checked park brake- went about 1/2 mile and won't move. Engine revs, van doesn't move-
Fluid level correct. Van has only 61000 miles- trans serviced regularly- Is a 3/4 ton
Mopar friendly shop is checking it out
torque converter? trans? AOD controls?
Worked it hard the last coup;e months moving...
Any thoughts- similar experiences?
thanks
Re: 2000 ram van trans problem [Re: GibW340] #1723237
01/07/15 02:49 AM
01/07/15 02:49 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Have you tried to move the van again after it left you stranded? After sitting, if it will move for a short period and then stop again, the filter is likely plugged. Plugged filter means the trans needs to come apart to find the cause of the debris in the filter. Even with the electronic controls dead the trans will still move but not shift. Easiest thing would be to drop the pan and look to see what has settled to the bottom and is stuck to the magnet and go from there.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2000 ram van trans problem [Re: GibW340] #1723238
01/07/15 10:15 AM
01/07/15 10:15 AM
Guitar Jones Offline
Was it making any unusual noises?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 2000 ram van trans problem [Re: Guitar Jones] #1723239
01/08/15 09:36 PM
01/08/15 09:36 PM
Frederick , MD
GibW340 Offline OP
GibW340  Offline OP
Frederick , MD
no - nothing unusual or our of ordinary at all until I tried to accelerate from light....
The shop dropped the pan expecting debris but nothing at all- fluid a little dark and a little burnt spell. Pulled trans- torn down and found nothing... going to talk to a shop who does only trans for insight- maybe torque converter?
Re: 2000 ram van trans problem [Re: GibW340] #1723240
01/14/15 03:27 PM
01/14/15 03:27 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Lip seal let loose would be my first thought.
Re: 2000 ram van trans problem [Re: GibW340] #1723241
01/14/15 04:59 PM
01/14/15 04:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Probably lost the pump; not uncommon and, typically, gives no warning.
Re: 2000 ram van trans problem [Re: John_Kunkel] #1723242
01/15/15 10:19 PM
01/15/15 10:19 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
been there done that
Re: 2000 ram van trans problem [Re: John_Kunkel] #1723243
01/16/15 10:05 AM
01/16/15 10:05 AM
Frederick , MD
GibW340 Offline OP
GibW340  Offline OP
Frederick , MD
Thanks for thoughts guys- had to put a reman trans in it- Hope to get a big refund at tax time
