Re: 2000 ram van trans problem
[Re: GibW340]
#1723237
01/07/15 02:49 AM
01/07/15 02:49 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Have you tried to move the van again after it left you stranded? After sitting, if it will move for a short period and then stop again, the filter is likely plugged. Plugged filter means the trans needs to come apart to find the cause of the debris in the filter. Even with the electronic controls dead the trans will still move but not shift. Easiest thing would be to drop the pan and look to see what has settled to the bottom and is stuck to the magnet and go from there.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: GibW340]
#1723238
01/07/15 10:15 AM
01/07/15 10:15 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Was it making any unusual noises?
[Re: John_Kunkel]
#1723242
01/15/15 10:19 PM
01/15/15 10:19 PM
Posts: 2,265 ILLINOIS
volaredon
ILLINOIS
Probably lost the pump; not uncommon and, typically, gives no warning.
been there done that
