Anyone broke an LY or 6 pack rod?
#1723191
01/06/15 01:32 PM
01/06/15 01:32 PM
Posts: 5,166 CT
GTX MATT
CT
Just for fun - the small block rod thread got me thinking. I have a 400 shortblock with a bent connecting rod, it is bent slightly in the non thrust direction.
I also have a friend with a 67 HP 440 sitting on his garage floor that he grenaded around 74, it has a couple of broken LY rods and a few that actually bent about 90 degrees and did not break. The engine is so screwed up that you can't get it apart. He shifted it around 6500-6800. Obviously he broke it with excessive RPM. And it had heavy TRW 6 pack slugs in it.
What stories do you guys have?
Re: Anyone broke an LY or 6 pack rod?
[Re: Twostick]
#1723200
01/06/15 07:17 PM
01/06/15 07:17 PM
Posts: 5,160 Texas
dannysbee
Texas
Yes I have. Ly. Will I again? No after market rods are too cheep and blue printed short blocks are too expensive.
Getting old just means you were smarter than some and luckier than others.
[Re: GTX MATT]
#1723202
01/06/15 07:39 PM
01/06/15 07:39 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Never broke a LY rod,but had one that a bolt snapped in...engine had 27 runs on it. New engine has a brand new set of LY's with ARP bolts and 6 pak slugs,but it will never go over 6000 rpm.
[Re: Chris2581]
#1723203
01/06/15 08:25 PM
01/06/15 08:25 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I put a lot of of high 9, low 10 second passes on stock 440 rods with upgraded rods bolts,and polished and shot blasted beams. Some broke, some didn't. Would I do it again with whats available now? HECK NO. Another thing to remember was that back then most of us were running stock cranks and HEAVY TRW or Sealed Power pistons.
