2600-3000 stall converter... Which brand? #1722872
01/06/15 02:29 AM
01/06/15 02:29 AM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Guys, building my 727 next week to put behind a stout 360 in a little Ram 50 that's back halved. Trying to decide what brand of stall to order for it.
Anyone have any insight as to which brands I should stay away from and which ones I might be happiest with?
Laine
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722873
01/06/15 04:05 AM
01/06/15 04:05 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I went with Ultimate Converter Concepts. They are a sponsor here. I'm quite happy with the 11" converter Lenny made for my Charger. It replaced a 9 3/4" No-Name converter that was great at WOT but too loose at cruising speeds.
Re: 2600-3000 stall converter... Which brand? [Re: Kern Dog] #1722874
01/06/15 11:13 AM
01/06/15 11:13 AM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
I'll check em out. Thanks.
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722875
01/06/15 11:27 AM
01/06/15 11:27 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Turbo Action has taken care of me over the years.
There street tight convcertors are awesome for hot street cars.
MLR426
Re: 2600-3000 stall converter... Which brand? [Re: MLR426] #1722876
01/06/15 11:29 AM
01/06/15 11:29 AM
scratchnfotraction Offline
MLR426
x2
Re: 2600-3000 stall converter... Which brand? [Re: scratchnfotraction] #1722877
01/06/15 12:10 PM
01/06/15 12:10 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I am not a racer, but I have a nice PTC converter in my 340 Dart that has been great on the street and occasional strip pass for almost 13 years.
PTC is in Muscle Shoals I believe.
http://www.ptcrace.com/
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: 2600-3000 stall converter... Which brand? [Re: 19swinger70] #1722878
01/06/15 12:38 PM
01/06/15 12:38 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Dynamic 9.5" behind my 360 is great mine flashes at 4,400rpm very consistent.
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722879
01/06/15 08:08 PM
01/06/15 08:08 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Turbo Action! Great products and service.
www.turboaction.com
Nautilus Racing-
Re: 2600-3000 stall converter... Which brand? [Re: Chris2581] #1722880
01/06/15 10:56 PM
01/06/15 10:56 PM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
www.turboaction.com
Another vote for Turbo action. Excellent customer service. My tight 10" is pretty sweet to cruise around with, and helped pull 1.54 60 ft times in 3600 lb w/ driver Cuda. Stock suspension with sticky tires. Racing and driving for 4 years and no problems at all.
Re: 2600-3000 stall converter... Which brand? [Re: Chris2581] #1722881
01/06/15 10:59 PM
01/06/15 10:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
There are alot of good converter companies out here. I have used two different ones in my street/strip cars and they have both worked to 100% of my satisfaction. Turbo Action of cousre are top notch converters and the Luppo Dynamic Converter I use in my 63 now as its been in my 63 since June 2006 when I put it on the road. And we use a Dynamic converter in my sons Dart. The Dynamic converter works great in my 63 as it does just what I wanted which is drive around like a normal converter and at the track it launches good enough for me to pull a 1.50 sixty ft in my 3700 lb 10.70 street car on just SS springs. Yea I have been 100% happy with my Dynamic and Turbo Action converters. Ron
Re: 2600-3000 stall converter... Which brand? [Re: 383man] #1722882
01/07/15 12:35 AM
01/07/15 12:35 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I ran a Hughes off the shelf (Summit) 11" 3000 stall converter for years in my 67 440 Dart. No problems with it, and with a Summit discount it was one of the cheapest brand name converters at the time.
Re: 2600-3000 stall converter... Which brand? [Re: Exit1965] #1722883
01/07/15 04:07 AM
01/07/15 04:07 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
PTC in a 10 inch would be good, you could spend more. don't think you need to
Re: 2600-3000 stall converter... Which brand? [Re: 383man] #1722884
01/07/15 07:17 AM
01/07/15 07:17 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Another vote for Turbo Action here I been running a 3000 stall of there's for years....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 2600-3000 stall converter... Which brand? [Re: OA5599] #1722885
01/07/15 11:35 AM
01/07/15 11:35 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
www.turboaction.com
Yes like I mentioned earlier in this thread the tight street convertors are a good product that gives you the best of both worlds in one convertor. Normal driving is good and when you mash the gas it breaks loose and flashes with the power you put against it to give you the performance you want. I have a 3800ST Street Tight and it workS great in my 3,400 lb 70 Cuda with a 600 hp hemi and 410 gears. They are great convertors and the company gives great service.
MLR426
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722886
01/07/15 03:40 PM
01/07/15 03:40 PM
I need to know if this is for street only, street and strip or race only before making any suggestions Any idea of how much HP, torque and weight? The more information you can provide the converter company the better It is easy to get a cheap converter,just shop around for the cheapest one Getting a good or excellent converter is a little harder Especially with your deal Take your time and do what your doing now (research)and then call each of those company and talk to them, take notes, and then decides once your sure you have the one(the correct company) you want when you place the order Good luck
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722887
01/08/15 01:17 AM
01/08/15 01:17 AM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I asked the same question about a year ago and ended up going with Dynamic (Frank Lupo) Converter. Like others have mentioned, there are quality converters available from several sources which will serve you well too.
When I ordered mine, they were offering a "winter special" price. They will ask for your car's specs and tailor a converter to meet your intentions. Comparing what they charged, I felt their price was very reasonable.
I upgraded from a B&M 2400 Holeshot which performed very well I will add for an off the shelf, 25 year old converter.
This is in a 340/416, 727/3:91, E-body street car that I take to the track 3-4 times a year.
Re: 2600-3000 stall converter... Which brand? [Re: Cab_Burge] #1722888
01/08/15 04:03 PM
01/08/15 04:03 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
I have talked to a couple companies now. Although they probably have a superior product, I can't justify a $900 converter in a transmission I'm building myself. $400-$550 is what I have in mind.
"Car" is a Ram 50 truck. I built the engine. Has smog heads from Mccandless, shaved .020, 2.02/1.60 stainless valves, pocket porting. Air gap intake, speed pro flat tops, mopar .484 cam (probably go bigger soon), edelbrock carb, shorty headers. TCI kit going into the trans next week.
Weight is approx 3000. (Probably end up less than that). Narrowed 8-3/4 rear, putting a 4:30 or 4:56 gear in. Has 29x18.5 Hoosiers and a 4 link rear.
It will go to the strip 5 or so weekends each year. I will cruise town with it too. Heck, I'll drive the damn thing to work for the fun of it.
Laine
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722889
01/08/15 04:45 PM
01/08/15 04:45 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
78 cop 440 - and this is from the service book that I'm looking at in front of me - has a factory stall speed of 2500-2800. They did this to help offset vehicle weight and smog effect. I know it's a long shot, but if you had one of those laying around, give it a shot. That's a good factory H/D part. I would imagine a 76 and 77 would be the same. Just a suggestion. I know there's a weight and perhaps even a torque difference but if you're making pretty good power, you might get right into the range you're looking for
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 2600-3000 stall converter... Which brand? [Re: VincentVega] #1722890
01/08/15 09:00 PM
01/08/15 09:00 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
I have a factory converter labeled "High". If all else fails I could have it cleaned and put it in. I think I'd rather get a new though. Looks like I'll have to just order one from summit or jegs. B&M, Hugh's, TCI....
Re: 2600-3000 stall converter... Which brand? [Re: Lmopar69] #1722891
01/08/15 09:02 PM
01/08/15 09:02 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Does it have a P/N on it? I wouldn't mind doing some research for you
