Re: 2600-3000 stall converter... Which brand?
[Re: MLR426]
#1722876
01/06/15 11:29 AM
01/06/15 11:29 AM
Posts: 15,487 Florida
scratchnfotraction
Turbo Action has taken care of me over the years. There street tight convcertors are awesome for hot street cars.
MLR426
x2
[Re: scratchnfotraction]
#1722877
01/06/15 12:10 PM
01/06/15 12:10 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I am not a racer, but I have a nice PTC converter in my 340 Dart that has been great on the street and occasional strip pass for almost 13 years. PTC is in Muscle Shoals I believe. http://www.ptcrace.com/
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: Chris2581]
#1722880
01/06/15 10:56 PM
01/06/15 10:56 PM
Posts: 834 Beavercreek, Ohio
OA5599
Beavercreek, Ohio
Turbo Action! Great products and service.
www.turboaction.com
Another vote for Turbo action. Excellent customer service. My tight 10" is pretty sweet to cruise around with, and helped pull 1.54 60 ft times in 3600 lb w/ driver Cuda. Stock suspension with sticky tires. Racing and driving for 4 years and no problems at all.
[Re: Chris2581]
#1722881
01/06/15 10:59 PM
01/06/15 10:59 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
There are alot of good converter companies out here. I have used two different ones in my street/strip cars and they have both worked to 100% of my satisfaction. Turbo Action of cousre are top notch converters and the Luppo Dynamic Converter I use in my 63 now as its been in my 63 since June 2006 when I put it on the road. And we use a Dynamic converter in my sons Dart. The Dynamic converter works great in my 63 as it does just what I wanted which is drive around like a normal converter and at the track it launches good enough for me to pull a 1.50 sixty ft in my 3700 lb 10.70 street car on just SS springs. Yea I have been 100% happy with my Dynamic and Turbo Action converters. Ron
[Re: 383man]
#1722884
01/07/15 07:17 AM
01/07/15 07:17 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Another vote for Turbo Action here I been running a 3000 stall of there's for years....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: OA5599]
#1722885
01/07/15 11:35 AM
01/07/15 11:35 AM
Posts: 4,799 ILL
MLR426
ILL
www.turboaction.com
Yes like I mentioned earlier in this thread the tight street convertors are a good product that gives you the best of both worlds in one convertor. Normal driving is good and when you mash the gas it breaks loose and flashes with the power you put against it to give you the performance you want. I have a 3800ST Street Tight and it workS great in my 3,400 lb 70 Cuda with a 600 hp hemi and 410 gears. They are great convertors and the company gives great service.
MLR426
[Re: Lmopar69]
#1722886
01/07/15 03:40 PM
01/07/15 03:40 PM
Posts: 43,195 Bend,OR USA
Cab_Burge
I need to know if this is for street only, street and strip or race only before making any suggestions Any idea of how much HP, torque and weight? The more information you can provide the converter company the better It is easy to get a cheap converter,just shop around for the cheapest one Getting a good or excellent converter is a little harder Especially with your deal Take your time and do what your doing now (research)and then call each of those company and talk to them, take notes, and then decides once your sure you have the one(the correct company) you want when you place the order Good luck
[Re: Lmopar69]
#1722887
01/08/15 01:17 AM
01/08/15 01:17 AM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
I asked the same question about a year ago and ended up going with Dynamic (Frank Lupo) Converter. Like others have mentioned, there are quality converters available from several sources which will serve you well too.
When I ordered mine, they were offering a "winter special" price. They will ask for your car's specs and tailor a converter to meet your intentions. Comparing what they charged, I felt their price was very reasonable.
I upgraded from a B&M 2400 Holeshot which performed very well I will add for an off the shelf, 25 year old converter.
This is in a 340/416, 727/3:91, E-body street car that I take to the track 3-4 times a year.
[Re: Cab_Burge]
#1722888
01/08/15 04:03 PM
01/08/15 04:03 PM
Posts: 392 Doniphan, Nebraska
Lmopar69
Doniphan, Nebraska
I have talked to a couple companies now. Although they probably have a superior product, I can't justify a $900 converter in a transmission I'm building myself. $400-$550 is what I have in mind.
"Car" is a Ram 50 truck. I built the engine. Has smog heads from Mccandless, shaved .020, 2.02/1.60 stainless valves, pocket porting. Air gap intake, speed pro flat tops, mopar .484 cam (probably go bigger soon), edelbrock carb, shorty headers. TCI kit going into the trans next week.
Weight is approx 3000. (Probably end up less than that). Narrowed 8-3/4 rear, putting a 4:30 or 4:56 gear in. Has 29x18.5 Hoosiers and a 4 link rear.
It will go to the strip 5 or so weekends each year. I will cruise town with it too. Heck, I'll drive the damn thing to work for the fun of it.
Laine
[Re: Lmopar69]
#1722889
01/08/15 04:45 PM
01/08/15 04:45 PM
Posts: 1,106 Northeast
VincentVega
Northeast
78 cop 440 - and this is from the service book that I'm looking at in front of me - has a factory stall speed of 2500-2800. They did this to help offset vehicle weight and smog effect. I know it's a long shot, but if you had one of those laying around, give it a shot. That's a good factory H/D part. I would imagine a 76 and 77 would be the same. Just a suggestion. I know there's a weight and perhaps even a torque difference but if you're making pretty good power, you might get right into the range you're looking for
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: Lmopar69]
#1722891
01/08/15 09:02 PM
01/08/15 09:02 PM
VincentVega
Northeast
Does it have a P/N on it? I wouldn't mind doing some research for you
