4 speed pedals uneven??? #172198
12/21/08 12:36 PM
12/21/08 12:36 PM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
I converted a 70 Charger from a power brake/automatic console to a power brake 4 speed and my clutch pedal is about 2 1/2 inches higher then my brake. I used the original booster & m/c (rebiult) & a set of 70 pedals. Is this normal or have i done something wrong??? Any Help would be great.
Re: 4 speed pedals uneven??? [Re: 6pktgo] #172199
12/21/08 12:46 PM
12/21/08 12:46 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Its normal for them not to sit even, I dont know about 2.5" difference though.
Re: 4 speed pedals uneven??? [Re: AdamR] #172200
12/21/08 12:54 PM
12/21/08 12:54 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
On a power brake car, the brake pedal sits much lower than the clutch pedal
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 4 speed pedals uneven??? [Re: 69L78Nova] #172201
12/21/08 12:56 PM
12/21/08 12:56 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Mine does too. Although a friend's challenger does not-- PB/4speed car. Don't know why though.
Re: 4 speed pedals uneven??? [Re: Pacnorthcuda] #172202
12/21/08 02:31 PM
12/21/08 02:31 PM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
Is there a different brake pedal linkage for a 70 or maybe a different bracket of sorts? Anyone have a 68 or 69 B Body that knows or maybe a 71? Thanks Again Moparts
Re: 4 speed pedals uneven??? [Re: 6pktgo] #172203
12/21/08 02:47 PM
12/21/08 02:47 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My 68 RR 4-speed, power disc brake car, brake pedal sits much lower than the clutch pedal, comes in very handy when on a steep hill for holding brake and also giving a bit of throttle as i let of the clutch
Re: 4 speed pedals uneven??? [Re: ademon] #172204
12/21/08 03:50 PM
12/21/08 03:50 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I believe the lower brake pedal came with the advent of disc brakes.. I remember first seeing them when these cars were new and discs became more of a standard than an option, and thinking something was wrong also.... Just my 2 cents..
Re: 4 speed pedals uneven??? [Re: minivan] #172205
12/21/08 04:02 PM
12/21/08 04:02 PM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
ALL 2 cents are GREATLY appreciated & worth every bit ,as i`m about to put the column in place and every part has been meticulously restored to original condition or very close and it makes getting at some other parts very difficult. Thanks Again
Re: 4 speed pedals uneven??? [Re: 6pktgo] #172206
12/21/08 04:47 PM
12/21/08 04:47 PM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
In my old '74 Power Wagon the clutch pedal sits a little lower than the brake pedal.
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: 4 speed pedals uneven??? [Re: Ryan_340] #172207
12/21/08 11:41 PM
12/21/08 11:41 PM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
Anyone have a untouched big block 70 Charger,Road Runner,Super Bee with a pic of the pedals ??
Re: 4 speed pedals uneven??? [Re: 6pktgo] #172208
12/21/08 11:46 PM
12/21/08 11:46 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
Thank God it's not just my car. I thought something was goofy about the pedals.
I'm going to have to fix it though. Can't stand it.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
Re: 4 speed pedals uneven??? [Re: go-fish] #172209
12/22/08 01:29 AM
12/22/08 01:29 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
My 68 gtx is a factory 4spd with power disc brake option and the pedals sit perfectly level to each other. I have since converted it to manual brakes and the pedals are still nice, straight and level. Sounds like some of you guys have some issues.
Re: 4 speed pedals uneven??? [Re: SCATPK] #172210
12/22/08 09:33 AM
12/22/08 09:33 AM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
Now i REALLY DON`T want to reinstall the column til i get this fixed !!! Anyone know about a different pedal rod maybe?
Re: 4 speed pedals uneven??? [Re: SCATPK] #172211
12/22/08 11:06 AM
12/22/08 11:06 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I cant imagine my brake pedal as high as my clutch pedal! I can't remember a car or truck including large trucks that i have driven where the brake pedal wasn't lower than the clutch, sometimes just a little bit but in those cases the clutch pedal was almost even with the throttle pedal, in other cases like my 68 RR with power front disc the clutch pedal is much higher than the gas pedal and having the brake pedal just a bit higher than the gas pedal makes it much smoother to drive, like taking off on a hill, i just have to move my foot from side to side, not lift my whole leg. Besides the clutch pedal rests at the rubber bumper on its stop, and the brake rests on its stop which includes the brake switch so i dont think their much adjustment
Re: 4 speed pedals uneven??? [Re: ademon] #172212
12/22/08 11:17 AM
12/22/08 11:17 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Power brake pedal (with correct pivot linkage) will sit lower than the clutch. Manual brakes use a straight push rod and will be closer to even with the clutch pedal.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 4 speed pedals uneven??? [Re: ademon] #172213
12/22/08 11:29 AM
12/22/08 11:29 AM
Hamburg - Germany
SuperRob Offline
SuperRob  Offline
Hamburg - Germany
same here, car is a 69 bee
Re: 4 speed pedals uneven??? [Re: SuperRob] #172214
12/22/08 01:58 PM
12/22/08 01:58 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I've had a '68 Charger,and two '69 road runners, all manual drums. all the brake pedals sat lower than the clutch, and so does my '85 D100 w/ power disc.
1981 Dodge D150 360 auto
Re: 4 speed pedals uneven??? [Re: basketcase] #172215
12/22/08 02:58 PM
12/22/08 02:58 PM
California
mickm Offline
mickm  Offline
California
mine is a conversion, so it is hard to use it as an example. but i assume the pedal assembly is stock? i don't know if there is anyone reproducing those.
mine is manual drum, and the pedals sit almost dead even, exactly the way i like it
Re: 4 speed pedals uneven??? [Re: mickm] #172216
12/22/08 05:17 PM
12/22/08 05:17 PM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
Pedal assembly (for a 70 B Body, but will fit 68&69 also),linkage (was in the car),power brake booster and m/c are all original,just restored, even down to the right clutch pedal with the hole (only found on the 70 pedal) for the neutral safety switch.
Re: 4 speed pedals uneven??? [Re: 6pktgo] #172217
12/22/08 08:53 PM
12/22/08 08:53 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Also restored a 69.5 bird with 4spd a few years back with manual drum brakes and the pedals were level with eachother on that car as well.
