Re: 4 speed pedals uneven???
[Re: AdamR]
#172200
12/21/08 12:54 PM
12/21/08 12:54 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
On a power brake car, the brake pedal sits much lower than the clutch pedal
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#172201
12/21/08 12:56 PM
12/21/08 12:56 PM
Posts: 21,909 Kirkland, Washington
Pacnorthcuda
Mine does too. Although a friend's challenger does not-- PB/4speed car. Don't know why though.
[Re: 6pktgo]
#172208
12/21/08 11:46 PM
12/21/08 11:46 PM
Posts: 693 Coronado, CA
go-fish
Coronado, CA
Thank God it's not just my car. I thought something was goofy about the pedals. I'm going to have to fix it though. Can't stand it.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
[Re: SCATPK]
#172211
12/22/08 11:06 AM
12/22/08 11:06 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
My 68 gtx is a factory 4spd with power disc brake option and the pedals sit perfectly level to each other. I have since converted it to manual brakes and the pedals are still nice, straight and level. Sounds like some of you guys have some issues.
I cant imagine my brake pedal as high as my clutch pedal! I can't remember a car or truck including large trucks that i have driven where the brake pedal wasn't lower than the clutch, sometimes just a little bit but in those cases the clutch pedal was almost even with the throttle pedal, in other cases like my 68 RR with power front disc the clutch pedal is much higher than the gas pedal and having the brake pedal just a bit higher than the gas pedal makes it much smoother to drive, like taking off on a hill, i just have to move my foot from side to side, not lift my whole leg. Besides the clutch pedal rests at the rubber bumper on its stop, and the brake rests on its stop which includes the brake switch so i dont think their much adjustment
[Re: ademon]
#172212
12/22/08 11:17 AM
12/22/08 11:17 AM
Posts: 4,285 Ohio
64dodge572
Ohio
Power brake pedal (with correct pivot linkage) will sit lower than the clutch. Manual brakes use a straight push rod and will be closer to even with the clutch pedal.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: ademon]
#172213
12/22/08 11:29 AM
12/22/08 11:29 AM
Posts: 178 Hamburg - Germany
SuperRob
Hamburg - Germany
My 68 RR 4-speed, power disc brake car, brake pedal sits much lower than the clutch pedal, comes in very handy when on a steep hill for holding brake and also giving a bit of throttle as i let of the clutch
same here, car is a 69 bee
[Re: SuperRob]
#172214
12/22/08 01:58 PM
12/22/08 01:58 PM
Posts: 7,841 east side of Ohio
basketcase
east side of Ohio
I've had a '68 Charger,and two '69 road runners, all manual drums. all the brake pedals sat lower than the clutch, and so does my '85 D100 w/ power disc.
1981 Dodge D150 360 auto
