Page 1 of 3 1 2 3
US car tools K-Frame stand #1721523
01/04/15 05:06 PM
01/04/15 05:06 PM
Valencia, CA
K
kpkube Offline OP
kpkube  Offline OP
K
Valencia, CA
Hi,
Does anyone have a US car tools k-Frame stand? how do you like it?
Re: US car tools K-Frame stand [Re: kpkube] #1721524
01/04/15 05:50 PM
01/04/15 05:50 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
We have a US Tool's K-frame & body dolly set. Worked sweet!
`68 Barracuda 340-S
Re: US car tools K-Frame stand [Re: FASTBACK340] #1721525
01/04/15 06:07 PM
01/04/15 06:07 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Love it! I sell them too
Re: US car tools K-Frame stand [Re: kpkube] #1721526
01/04/15 06:46 PM
01/04/15 06:46 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Would like to see pics of one used on an install with the front only being raised on the car (without a 4 post lift).
It's seems a little high for that. I know it's that way to clear the drooping suspension. But some tie the suspension up to get everything a little lower.
How low does the Trans and K-member support go?
P.S. Welcome Keith!
Re: US car tools K-Frame stand [Re: autoxcuda] #1721527
01/04/15 07:12 PM
01/04/15 07:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
They work fine, especially if using the US Cartool frame lift setup (someone else's pics here) . The only concern would be ceiling clearance, I do mine in the driveway.
Re: US car tools K-Frame stand [Re: ScottSmith_Harms] #1721528
01/04/15 07:13 PM
01/04/15 07:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
You can make your own or buy one done. This kit costs $199.00 and is very well made
Re: US car tools K-Frame stand [Re: ScottSmith_Harms] #1721529
01/04/15 08:31 PM
01/04/15 08:31 PM
Valencia, CA
K
kpkube Offline OP
kpkube  Offline OP
K
Valencia, CA
How is the K-frame held on the stand. Any pics on how it is mounted?
Is there an instruction sheet how to mount it?
Re: US car tools K-Frame stand [Re: kpkube] #1721530
01/04/15 08:34 PM
01/04/15 08:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Very simple, two long bolts with larger flat washers come from the bottom and up through the K-member through the factory drain holes and bolt it on. I used thin rubber "washers" under the steel washers on both sides to protect the paint. You don't need to over tighten the bolts, just snug is good enough.
Re: US car tools K-Frame stand [Re: ScottSmith_Harms] #1721531
01/04/15 09:35 PM
01/04/15 09:35 PM
Valencia, CA
K
kpkube Offline OP
kpkube  Offline OP
K
Valencia, CA
Thanks. My K-Frame doesn't have those holes on top. it looks like this (not my pic)
The holes i see from the bottom don't go all the way through.
Re: US car tools K-Frame stand [Re: kpkube] #1721532
01/04/15 09:38 PM
01/04/15 09:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
On your style you can just rest the pegs from the bottom into the drain holes you have and it will sit in place once you have the trans supported.
Re: US car tools K-Frame stand [Re: ScottSmith_Harms] #1721533
01/04/15 09:43 PM
01/04/15 09:43 PM
Valencia, CA
K
kpkube Offline OP
kpkube  Offline OP
K
Valencia, CA
Got it, Thanks.
Re: US car tools K-Frame stand [Re: ScottSmith_Harms] #1721534
01/04/15 09:51 PM
01/04/15 09:51 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
The Road Runner I posted above only had the lower holes in the K frame. Held everything nice and securely while being able to easily position it. While the frame jig worked nicely, the body dolly was a bit clunky with the hard wheels on rough pavement though. Rubber or inflatable would be ideal. Transporting the shell from the metal shop to paint to assembly always shook out a little more dust from the bowels….. but our driveway is a bit rough. The paint shop loved it…..
`68 Barracuda 340-S
Re: US car tools K-Frame stand [Re: FASTBACK340] #1721535
01/04/15 10:44 PM
01/04/15 10:44 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Build your own, $60 of steel, I think less than $20 for the front mount.
Careful, your character's showing!
Re: US car tools K-Frame stand [Re: mopar346] #1721536
01/04/15 10:47 PM
01/04/15 10:47 PM
mopar346 Offline
mopar346  Offline
I actually used the cradle as the basis for a run stand and broek my engine in on it.
Re: US car tools K-Frame stand [Re: mopar346] #1721537
01/04/15 10:48 PM
01/04/15 10:48 PM
mopar346 Offline
mopar346  Offline
45* on the cherry picker, I had the rear tires on so it rolled with it.
Re: US car tools K-Frame stand [Re: mopar346] #1721538
01/04/15 10:52 PM
01/04/15 10:52 PM
mopar346 Offline
mopar346  Offline
Straps holding the craddle in place, 69 Camaro core support, 69 Camaro aluminum radiator, Cuda lower hose, 79 PW upper hose, switchs and gauges. All stuff I just had laying around the shop, wala engine run stand with no expense. OK, so I'm cheap.
Re: US car tools K-Frame stand [Re: mopar346] #1721539
01/04/15 10:53 PM
01/04/15 10:53 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
I agree, we could have made one for less than what was paid for the unit. Although it does work well and is well made…..
BTW: Nice cradle you fabled up.
`68 Barracuda 340-S
Re: US car tools K-Frame stand [Re: FASTBACK340] #1721540
01/04/15 10:55 PM
01/04/15 10:55 PM
mopar346 Offline
mopar346  Offline
There's probably more than one copy right infringement. You ought see my dash stand.
Re: US car tools K-Frame stand [Re: mopar346] #1721541
01/04/15 11:02 PM
01/04/15 11:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree, none of these mail order solutions are for everyone, especially guys who have the time, materials, a decent work space, some skill, and a welder. However, convenience has it's price, and the US Cartool products are very nice. Pick your poison.
Re: US car tools K-Frame stand [Re: mopar346] #1721542
01/04/15 11:06 PM
01/04/15 11:06 PM
Valencia, CA
K
kpkube Offline OP
kpkube  Offline OP
K
Valencia, CA
Would like to see the dash stand, Please post pics. Thanks
Page 1 of 3 1 2 3
