Is it possible to date code a cruise control servo? #1721366
01/04/15 12:42 PM
01/04/15 12:42 PM
Leesburg, VA
V
VA_Mopars Offline OP
V
Leesburg, VA
I know the servo unit was a very consistent part through the late 70s, but is the best way to determine the proper date of part to see if would be appropriate for my 69 Charger?
Thanks,
Joe
Re: Is it possible to date code a cruise control servo? [Re: VA_Mopars] #1721367
01/04/15 01:42 PM
01/04/15 01:42 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
The 1968-1969 servo is different than the 1970+ servo. The system that shut the speed control off when the brakes are applied were vacuum powered in 1968-1969 and in 1970 that was changed to an electric shut off system. That meant differences in the servo. The later electric shut off was much simpler and can be adapted to the 1969 and earlier cars. Here's a pic of an NOS servo with a 1969 date code.
Re: Is it possible to date code a cruise control servo? [Re: twodoorpost] #1721368
01/04/15 01:43 PM
01/04/15 01:43 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
servo comparison pic
Re: Is it possible to date code a cruise control servo? [Re: twodoorpost] #1721369
01/04/15 03:35 PM
01/04/15 03:35 PM
Leesburg, VA
V
V
Leesburg, VA
Thanks for the detailed response. It was exactly what I needed.
Joe
Re: Is it possible to date code a cruise control servo? [Re: VA_Mopars] #1721370
01/04/15 05:01 PM
01/04/15 05:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Thanks for bringing this topic up.
Are there and dates or part numbers stamped into the parts?
Or were they just ink stamps?
Re: Is it possible to date code a cruise control servo? [Re: NANKET] #1721371
01/04/15 05:56 PM
01/04/15 05:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Serve has an ink stamp date.....not aware of a date code on any other underhood parts
Re: Is it possible to date code a cruise control servo? [Re: gtx6970] #1721372
01/04/15 06:23 PM
01/04/15 06:23 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
My experience is that there were many more servos without any date code than with.
Re: Is it possible to date code a cruise control servo? [Re: gtx6970] #1721373
01/04/15 06:25 PM
01/04/15 06:25 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Bill, I'm must not understand what you meant, I'm sure you have seen some of these underhood parts that are date stamped: (not counting part on the engine)
Starter relay, horns, date stamped with week and year
Original tank mounted (67 & up style) window washer pump/motor has a date on it
Master cylinder 1970 hemi/ and disc brake date stamped on side
Radiators stamped day/year on RH bracket
Hood latch and catch day/year
Wiper motor barell stamped day and year
K member and Rivets on control arms stamped day and year
Re: Is it possible to date code a cruise control servo? [Re: NANKET] #1721374
01/04/15 06:32 PM
01/04/15 06:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Question was asking about cruise control parts
