Re: Where to buy rivets for frame?
[Re: DusterDave]
#1721289
01/05/15 03:26 AM
01/05/15 03:26 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The local tractor supply chain sells rivets for farm equipment. Not sure how big they have though, it's only place I can think of.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: DusterDave]
#1721291
01/05/15 11:19 AM
01/05/15 11:19 AM
Posts: 1,030 NH
torredcuda
NH
I have good air hammer and I use to work on Grumman trucks so I have the right bits. I plan on welding it in also so the rivets are more for the correct look.
Won't the welds take away from the "correct look" you're after?
Welds will be on top and inside the frame so unless you stick your head up there you won`t see them, from the outside it`ll look factory.
I`ll try Tractor supply as there is one right in town.
[Re: wyldebill]
#1721294
01/06/15 09:32 PM
01/06/15 09:32 PM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
Another option, we did this on some street rod stuff. Take a grade 8 bolt and grind it down to look like a carriage bolt top. Zip it in with an impact and it'll be good.
I actually used carriage bolts. Filed the holes square and there you go!
[Re: wyldebill]
#1721297
01/07/15 09:47 PM
01/07/15 09:47 PM
redraptor
Greenville, PA
Most of the carriage bolts we come across are of a lower quality than grade 8
True. So are those rivets.
